0 Members and 134 Guests are viewing this topic.
br549
Geo:
I tried to replicate the experiment that you showed. I already had a solid state tesla coil set up,
so I used it instead of the fly-back for the HV source. Not sure if I did it correctly, but attached is a
little video and the results. I think I am going to try and do a few more experiments, trying to charge the cap from the ground side.
  http://youtu.be/YQXurQUrMYQ
Have a great day:
br549
Void
Nice demo BR549. It looks like the input current increases each time the capacitor is charging.
All the best...
GeoFusion
Hi there Guyz  ;)
I wanted to add some more interesting stuff to the video,
it took me a while but it's up now :) finally.
Enjoy.
https://www.youtube.com/watch?v=n3hU5CCBt5k
These new findings are awesome  and how to understand HV HF to be used to create this effect where ground wants ground for amplification.
Hoppy,
Yes, you'll get the same results when using battery :).
i'm very interested to try out with higher input voltages to see output :P. but yet it would turn out to be dangerous.
The only measuring I did is with amp clamp meter. but I need those analog amp meters and voltage meter too for results.
because I can't use my meter on the input when the system is connected to the ground,  the values go up and down. no steady reading.
it's because of the radiant perhaps.
You know I might be possible what I see now that it can run without ground to light the lights as how kapanadze said he did.
lets see how far we manage ;).
Ahhh yes grum's vid also shows the effect :),
:P nicee man, it's like how Urfa also did with his setup of ruslan's. But you managed too, that great news ;D.
So this virtual ground must be one of the keys maybe but let a coil be a virtual ground maybe?
Guesing this should be connected now to a coiling system like the one as Chubinidze. that uses ground connection to his Cap. ;)
Void,
yes i know, been playing around with Tesla coils too :). there ground end works the same way too. will arc on anything in it's path.
Remember this is to see the greater picture only on what happens with ground line connected. and using Aerial.
As we all now and talk about Don Smith and Akula/Ruslan devices, they have this effect happening with the ground ;).
Take a look at my latest ;), we need to brain storm on this. Yet I feel we are close to finding it, yet this is one great part of it.
br549:
Nicee man, and did this with a Kacher :), and a High value cap, has a different behavior, hmm try a cap with nanofarrat range or 0.0xxmf range. see if something happens. Keep on experimenting. :)
Cheerz guyz.
Acca
GeoFusion that is some wicked vido clip !
HF electricity is a really strange and the effects are equally strange..
I have combined electrostatic (no current) and 22 khz Rf in the same capacitor like the water
bottle that you have , except you may want to use a plastic water bottle made from polysterine
you can hold a charge inside the plastic bottle and one on the outside, now then you can eliminate
the metal wrap... just brush the out side of the bottle with a fine copper wires.  And inside drop a
stainless wire for the charge in the center of the bottle don't let the wire contact the top of the side
of the bottle you want to use the plastic lid with the through hole...
This will make a water capacitor that is impervious to RF HF discharge .....
Water can be from the tap... now the Rf side of the HF will still not discharge the bottle.. but
will go through the bottle like it is not there,  it is the dirt ground that you are showing in your clip that
is RF side of the spark oscillations...
You have at least three different manifestations of the electricity in your clip.
as well as cold type electric charge the clamp AC will not show, for that you need a laser temp meter to see the
temperature drop.
I am a loner and work on cold beam plasma effects and have made discoveries just like you have..
great video clip  and keep on ....
Acca...
Void
Nice video demo Geo. I can't really comment too much since you are still using a mains connected power supply.
Yes, the problem with using sparkgaps is they can mess up digital meters. That's where an analog ammeter can come in handy.
I have also noticed that using two separate grounds can sometimes give a bit of a boost to the output, and
that may well be why Kapadnadze used two grounds in his earlier device. It's interesting that you get more
light when you use sparkgaps. I have seen that as well before where a sparkgap gives more light. Something to do with
the pulsing. If someday you get an analog ammeter maybe you can use a battery and make some input current measurements
while you are trying different ground connections and spark gaps.  I usually avoid testing with sparkgaps too much because
it messes up my meters and scope, and computers, etc. :D By the way, concrete is somewhat conductive, so that is why you can get
a ground effect from concrete. That being the case, it is probably not a good idea to walk around bare feet on the concrete or ground
while testing with high voltage circuits. If you have some plastic or rubber soled shoes to use when testing with high voltage,
that might be a good idea. :) It looks nice and tropical where you live.  8)
All the best...
