0 Members and 584 Guests are viewing this topic.
NickZ
   Now, I wonder which one is the X-wire???
   I connected up my new longer earth ground line, down into my water well that's in my back yard. This long ground cable is actually two cables, 37.5 meters long, which will also be placed 10 meters apart from one another, at their individual cable ends. One cable end goes into my well, and the other into the ground.  Today I'll do some more testing, and report back, soon.
But, so far I can see that connecting this long ground cable does change the running frequencies on my device, and adds a bit more brightness to the bulbs.
magpwr
Quote from: MenofFather on February 12, 2015, 07:36:20 AM
Here old may try made selfrunning. https://www.youtube.com/watch?v=OsgZlYhjcRk
hi MenofFather,
May i ask if you have modified the slow bridge rectifier design for 50/60hz inside power supply unit with faster 4x diodes.
I think this bridge rectifier in power supply unit can be bypassed if you already have a high dc voltage but to ensure not to mix polarity else capacitor inside PSU will explode.
Do take note the PSU under 220volts needs around 360vdc...400vdc after bridge rectifier to function properly.But under 110volts setting it mere needs around 200vdc.
Maybe this explains why PSU light was blinking away even for your setup due to under voltage.
I remember you have previously charged a capacitor to somewhere below 1000volts.
May i ask if you can post the circuit diagram once more.I have lost track already.
Earlier i did a quick research and found that the WIMA MKP10 capacitor are indeed suited for pulse application.
But the Russian PIO capacitor 20uf base on one of Ruslan unboxing video would do the job for pulse application as well.
Once my nanosecond generator is fully assembled it will be connected to RG58 BNC cable which will be wound over multilayer coil then followed by 25 turns bifilar over RG58 cable."Dally's approach"
Screenshot of long descending ripple waveform is base on RG58 cable datasheet spec at 29pf per  meter and assume 16uH at 5 turns.
MenofFather
QuoteMay i ask if you have modified the slow bridge rectifier design for 50/60hz inside power supply unit with faster 4x diodes.
No. I rectife trought fast diodes first.
QuoteI remember you have previously charged a capacitor to somewhere below 1000volts.
Something like this. Why you need that?
http://realstrannik.ru/media/kunena/attachments/3866/implss.png
Stela
