0 Members and 648 Guests are viewing this topic.
Stela
This is not my site but that of a friend who wanted to help me, and you're not in my head.
Money is a tool and not an end to be. But I intend to be back on invesstissment . Any work deserves pay no? ;)
Ed morbus
Guys
stay where we do it for to get free energy ?
and ask the man pdf or schematic circuit info
dutch proverb watch the cat out of the tree
and we'll see where we end up
GeoFusion
Hi guyz,
Nice vid Stela,  :)
I think the most important part for my understanding is starting from 25:18 till the end of vid 45: 27
The pulsing of the core is what what is important here.
Guyz,
almost done with the filming of my findings with the TL494 circuit.
Some small replacements was needed too but it's working :).
The yoke on schematic is incomplete but I have it build as how it should be for the testings
Also tried Flyback transformer on the circuit, and makes the arc sing  :D so much fun with it.
First time creating a circuit board like that but Fully understand what is going on with it.
But this is so different from how a Mazilli works, just to state it now.
But as I see I could still output a good 1Kw with two 500Watt incandescent, on low lumin lv.
Ok will keep up with the update, Srry for latency,
was installing HHO in cars for buddies ;),
simple simple.
Cheerz guyz.
Got my 24V PSU finally, and the test will go on the ruslan coil too.
MenofFather
I yesterday speak with Ruslan and Ruslan everything explain how need made divice on 1 kW.
Need generator like this https://www.youtube.com/watch?v=TtjlIkgLJ7M who making 4-5 pulses, then pause, then again 4-5 pulses with frenquency push pull (27 kiloherc on Ruslan divice). Resonant capasitor 0,47 uF. Inducor 10 meters. Output coil 40 meters. Tesla coil can be 20 meters for 0.7 wire and 40 meters for 0.5 wire. Inductor on Tesla coil have 6 turns, wound turn to turn, with about 1 cm gap betwenn primary and secondary. On plus Tesla coil inductor go 24 volts. All system 24 volts.
First need wound of aliuminum plate on tube one turn not shorted. Then wound output coil, but always wound in same direction now. It have 6 layers, but now always need wound in same direction. Then inductor begin from same direction wound like multilayer coil, then gose to end, go back and wound again, in other words Tesla bifilar coil inductor is. Aluminum one turn go to ground. Multilayer coil first layer go to ground. Indutcot throught resistor go to graund, but if no automatic resonance ajustion, then resistor is not nessary, it needed to not burn generators, then signal gose from ferite ring secondary mounted on 3 turns resonans windings. On output multilayer coil is 0.22 uF capasitor and from it gose to hight speed 4 diodes and then on output is DC curent (can be capasitor 10 uF after diodes) and that gose to load and 220 to 24 volts power supply.
Quote from: Void on February 14, 2015, 10:16:46 AM
Hi all. The way I look at it, if a person doesn't show at least some very basic measurements,
and can't or will not answer some very basic and polite questions, then something sure seems wrong. ;)
All the best...
Ditto.
And the response you get from Stela is.... "Measures are useless."
Something sure seems wrong, all right.   What if your bank suddenly started telling you "measures are useless" when you asked about your balance? Or if you tell the cop who pulls you over for speeding.... "Measures are useless".....
Just take everything on faith! I have a system here that produced COP>3000. What, you doubt me, you want to see measurements that support my claim? But don't you know?
Measures are useless!!!!!
