0 Members and 844 Guests are viewing this topic.
Void
Quote from: Stela on February 16, 2015, 06:35:28 AM
All can free up energy. Everything is energy. Only the natural medium changes.
An electrical arc can not create energy, but just carry. An arc "is" heat, heat "is" loss !!
Normal classic effect. Eclairs = losses
Normal electricity goes shorter.
Hi Stela. I will take it step by step. Start with the very basics of a particular setup to understand what is normal,
and then continue doing tests with variations from there. By using an ammeter to constantly show the
input current to the flyback driver, it is possible to understand what is happening with the input power under
different conditions. Without the ammeter in place to monitor the input current, all a person can say is a light bulb is
sometimes lighting, and sometimes not.  ;)
All the best...
Void
Quote from: MenofFather on February 15, 2015, 02:42:46 AM
I yesterday speak with Ruslan and Ruslan everything explain how need made divice on 1 kW.
Need generator like this https://www.youtube.com/watch?v=TtjlIkgLJ7M who making 4-5 pulses, then pause, then again 4-5 pulses with frenquency push pull (27 kiloherc on Ruslan divice). Resonant capasitor 0,47 uF. Inducor 10 meters. Output coil 40 meters. Tesla coil can be 20 meters for 0.7 wire and 40 meters for 0.5 wire. Inductor on Tesla coil have 6 turns, wound turn to turn, with about 1 cm gap betwenn primary and secondary. On plus Tesla coil inductor go 24 volts. All system 24 volts.
First need wound of aliuminum plate on tube one turn not shorted. Then wound output coil, but always wound in same direction now. It have 6 layers, but now always need wound in same direction. Then inductor begin from same direction wound like multilayer coil, then gose to end, go back and wound again, in other words Tesla bifilar coil inductor is. Aluminum one turn go to ground. Multilayer coil first layer go to ground. Indutcot throught resistor go to graund, but if no automatic resonance ajustion, then resistor is not nessary, it needed to not burn generators, then signal gose from ferite ring secondary mounted on 3 turns resonans windings. On output multilayer coil is 0.22 uF capasitor and from it gose to hight speed 4 diodes and then on output is DC curent (can be capasitor 10 uF after diodes) and that gose to load and 220 to 24 volts power supply.
Hi MenofFather.  I almost missed this comment from you. Ruslan keeps changing what he is saying. ;D
Since everything Ruslan is saying keeps changing, is Ruslan admitting that many/all of his previous video
demonstrations were all decoys/fakes, or what reason did he give for constantly changing what he
says will work? Ruslan just seems to be playing games...  ;)
All the best...
MenofFather
Ruslan not ewerything god understand in past, he say. And most sucsesfull his dive be with dally generator and he now think, that not need be leave this divice, but develop. Now the last divice is more easy ajustable, with kacher he say, that wery be dificult ajust.
Quote from: Void on February 16, 2015, 01:42:10 PM
Hi magpwr. Not sure what to make of that video. If you are putting enough power
into the primary, I guess you should be able to light the light bulb even if the secondary
only has one turn. I have watched a number of this guy's videos. He has another video
called "Free Energy generator is not possible." that is similar to the video you linked :)
All the best...
I like this one:
http://www.youtube.com/watch?v=RKspT_CGAtE
Void
Quote from: MenofFather on February 17, 2015, 03:32:25 AM
Hi MenofFather. My problem with Ruslan is he seems to have been presenting his different variations
of devices as good working devices, but then all of a sudden he turns around and says it is not good
and that he is now trying something quite different. Someone made a video of trying to tune the kacher frequency
similar to what Ruslan showed in his own video using the current transformer to monitor the 'beard waveform'
in the inductor tuned loop, and Ruslan made a comment on this guy's video telling him:
"This is not the correct scheme! I posted a video of their new scheme with explanations.
There Kacher controlled. Do not worry with these stupid things .... it will not work!"
Here the guy was spending a whole lot of time and effort trying to replicate what Ruslan showed in
his own video as a working device, and then Ruslan makes that comment to the guy, telling
the guy that 'it is stupid and will not work'. Also, something was very suspicious about Ruslan's demonstration
of his claimed pulsed output capacitor device, which Ruslan said had no push pull inverter driver.
In one of Ruslan's videos Ruslan shorted the output capacitor right out with a screwdriver and the
lights did not dim. Obviously the device was not working the way Ruslan said it was working. The device
might not be a fake, but Ruslan does not appear to have been honest about what he was really doing.
If we give Ruslan the benefit of the doubt and say that maybe some of his devices really do self run,
then I think we can at least conclude that Ruslan is not telling people all the actual facts about his devices.
Ruslan appears to tell people what he wants them to think, and leaves out what he doesn't want people to know.
Here is the problem with these type of devices. The fact is that a genuine self running electric generator
is potentially worth a huge amount of money to whoever can really build one, and despite what anyone says
about wanting to give out all information freely to the public, when it comes right down to it most people will likely not
be able to resist the temptation to try to make money off such a device if they have one. There are lots of rich
corporations/investors around the world who will likely pay a lot of money to buy the technology rights to such a device.
If Ruslan really has figured out how to make self running devices similar to what Daly and Akula have shown,
it appears he is keeping some important details to himself, and very possibly releasing some false information from time
to time to try to keep other experimenters off the right track. When you look at the many things Ruslan has
been saying over the last year or so, there is various conflicting information as I have mentioned, and some things
seem to be deliberately misleading. Because of this, I think many people do not trust much of what Ruslan says
now, even if he really does know how to make a self running device. ;)
T.K.: Yes, that video with the magnets on the large toroid is interesting. I guess he is probably using really strong magnets
if that video is not a fake .
All the best...
