0 Members and 81 Guests are viewing this topic.
skywalker66
Quote from: lacphong on February 18, 2015, 01:11:05 PM
Hello everyone, I'm a new kid here :D I would really appreciate it if someone can help me with some of my questions below.
1.  According to the attached diagram, what value should I use for Capacitor C1?
2.  What kind of magnet wire should I use to wind kacher secondary coil?  Like wire gauge, wire length, tube size, and number of turns.
Thanks in advance.
Hi and Welcome!
According to ruslan,
1. C1 about 0.1uF WIMA MKP10, min. 400Vac is a good start
2. Kacher secondary: on pvc pipe 5cm diameter, gauge: 0.8, 0.81mm wire diameter, length on wire half of grenade's length (if grenade coil have 38m, then kacher use 19m),  the best turns slightly spaced between them, not tightly wounded.
this is my best guess, but no promise.
Good luck !
magpwr
To Russian members(Privet Товарищи),
Can anyone help to check with the creator of this circuit in Russian forum if the circuit as part of his device is able to achieve something interesting.
(Может кто-нибудь поможет проверить с создателем этой схеме в русском форуме, если схема как часть его устройство способно добиться чего-то интересного.)
I recall URFA previously used around 50volts to power kacher coil and this circuit is using rectified mains(110volts a/c)step up transformer to power kacher.
I just did a another verification of the circuit in breadboard including in the hex inverter 74HC04 with PLL as it is.
It seems this circuit square wave output from inverter from PLL pin 4 seems to be in phase with the sinewave or moustache waveform present at toroid for LM393.
This circuit i am testing out with TLC272 which produce better waveform than LM393 without the need for pullup resistor.
The led circuit output of PLL I/C pin 1 is not important at all.A simple green led with resistor is enough.
I am just curious what was the outcome like from the one whom design this circuit.
MenofFather
Schematic how explain Ruslan in last conference...
NickZ
  MenofFather:
  Why is the yoke's secondary coil shown in this diagram as not connected to anything?
  And also, just what is the small transformer (yellow color), that is shown as being part of the feed back path?
What are the turns, and type of that transformer? Is it a ferrite toroid? What Voltage and amperage is the output?
MenofFather
Quote from: NickZ on February 19, 2015, 09:05:09 AM
  MenofFather:
  1 Why is the yoke's secondary coil shown in this diagram as not connected to anything?
  2 And also, just what is the small transformer (yellow color), that is shown as being part of the feed back path?
1 Ruslan plan this coil conect to supplingh power for 6 turns coil in right side, but now this coil feeding from 24 volts. Grante must be wound always in one direction (not like be before: two first layer wound in one direction and second 4 layers in oposite direction), so now is better and highter voltage on output and not needed 26-28 turns coil.
2 Small transformer is curent transformer. You can not use them. It needed for automatic resonance ajustion (to hold automatic resonance with difernt load on 10 meters coil and C2). I not use automatic resonance, so I not ask Ruslan about turns and so on on that transformer, yes it toroid, it ferite toroid, not big, about 1 cm diameter.
Load must be not smaller 300 W.
