0 Members and 41 Guests are viewing this topic.
GeoFusion
Ed morbus :)
Thnx for the Vids,
especially Ruslan Kulabuhov energy device open internals 2
I studied the vid.
in there we see Yoke turnes connected to Kacher input rectified.
must be the 28 turns or more or less.
Meno
Hmmm but in lastest diagram of Ruslan it's like how a tesla coil needs to be connected to ground.
tesla coil Keeps the ground alive and calling out more particles form ground.
the source of external energy maybe so.
lets see how this works out ;)
will keep the updates when done ;)
Cheerz
NickZ
  MenofFather:
"Acording last Ruslan explanations here now no kacher. Now is controled Tesla coil, how he call. How you see emalated coil one end go directly to ground. In kacher it go to transitor base.
On out 28 turns windings, I think, can be too hight voltage (so in my last schematic I add choke to lower voltage (choosing proper choke and capasitors for needed voltage)). If you conect controled Tesla coil from granade output, then be more higher voltage than from 28 turns windings on yoke."
                                           end quote from MenoFather
    The voltage is higher at the grenade's 168 turns coil output, but, the amperage is lower, compared to the 28 turns coil output.
  Although both of these (yoke 28 turns to grenade's 168 turn coils are connected together, and also by a short jumper wire to the 3 turns coil at the tuning cap, in my set up, as was also shown by Ruslan.
  We need lots of amps ( 10+  amps?) from a feed back loop, to satisfy the push-pull's input appetite.
  The Kacher circuit can be powered by the yoke's 3 turns coil, as it has lower voltage, but, supposed to have high amp output.  Yet, I do not find that the 3 turns coil has a high amp output, on my set up, as it will barely light a small 110v bulb, by itself.
  I can't measure the actual amps, or voltages, at the grenades's output, only on the yoke's circuit input side. But it looks like, that my current feed-back loop is not enough to power the push-pull oscillator (yet), once disconnected from the battery source.
  I'm using three long outside earth grounds now, as well.
  Let me know more about the "controlled Tesla coil".  As my Kacher's circuit secondary coil output is not strong enough, compared to how Ruslan's HV spark looks, when it's jumping onto his finger.
