0 Members and 611 Guests are viewing this topic.
DreamThinkBuild
Hi All,
Not sure if this has been posted before but I stumbled across a patent which may have some relevance.
WO2014161057 (A1) - DEVICE AND PROCESS FOR THE GENERATION OF ELECTRICAL ENERGY
http://worldwide.espacenet.com/publicationDetails/biblio?CC=WO&NR=2014161057A1&KC=A1&FT=D
Looking for other patents to see if there is a correlation in capturing muons through a tuned coil.
NickZ
  Kapanadze?
  Maybe, but there's no feed-back loop.
  Worth trying to see if there's any extra current to be had. But, the 40w neon sign, may not even be able to light a 40 watt incandescent bulb.
  Are there any replications that are showing this working?
Void
Quote from: DreamThinkBuild on February 26, 2015, 11:50:59 AM
Hi All,
Hi DreamThinkBuild. That patent application is interesting. Thanks for the reference.
All the best...
magpwr
hi everyone,
Dally's related project- Nanosecond generator 1st round of circuit testing
Finally i got my long waited Damper diodes (TO-220 which i manually convert diode to SMD)from Hong Kong as shown in attached virtual circuit.
Good news my nanosecond PCB project is finally assembled for testing.
But unfortunately i am not using the right kind of mosfet for the job currently using expensive RF mosfet which did not yield results in KV.
This is the reason why i trust virtual more than actual experiment.
Later in the day i will be changing the mosfet to IRF840 since i do not have the ignition mosfet yet which yield the best result at 28volts.
The maximum repetition achieved at 149khz but screenshot is taken at 15khz.The limitation is at the mosfet driver TC4451.If i were to swap with IXDI414 (35volts max)driver i should able to achieve even faster repetition rate.
The nanosecond pulse width is around 10ns .The vpp is around 300volts.
The intention for creating this PCB board -The output will be RG58A coaxial cable which will produce nice ringing waveform from 10ns pulse. :) :) :)
Placing a probe nearby coaxial cable will reveal strength of magnetic field.
The current consumption is mere 110mA using 12volts which is boosted to 18volts.But this current draw will be increased to 2Amps once suitable mosfet is in place.
I have attached screenshot from 1st round of testing.
