0 Members and 187 Guests are viewing this topic.
AlienGrey
I have seen may quotes pointing to many different frequency's quoted as being the magic pixy dust frequency 1.7mhz as one 149k as well and many others and now 15 khz, you all appear to think if 8 will decide it out equally it will work, it bears no relation ship to anything any of the masters, Tesla Moray ever used,  has any one actually got any thing to work yet and if so just where is the energy coming from Any body, does any body know ? and if your engaged in any of these devices i suggest you find out exactly what your doing and of the correct way to do it amusing it is possible. Ps I wish you all luck I really  do.
magpwr
hi everyone,
This is the latest update related to my nanosecond generator related to Dally's and Ruslan maybe.
I have found a small bug in why my nanosecond generator was not producing high pulse amplitude.The root cause was the 10ohms thick film chip resistor rated 2watt which was not able to handle nanosecond pulse.Replacing with a common 10ohms 1watt resistor solved my problem somewhat.
Current consumption is still around 120mA at 12volts which is boosted to 30volts.
Using mosfet IRF840 my nanosecond generator is able to produce 656Vpp at 9.6ns.This mosfet will be changed to ignition mosfet for optimal performance at low voltage ~30volts instead of 50volts.The mosfet is now being driven at 24volts using mosfet driver IXDI414PI.
Important discovery to take note the RG58A coaxial cable used by Dally's is likely swapped at the input.The inner core needs to be ground or negative and the shield needs to be connected to pulse output.
I recall itsu was having problem with this setup few months back.
Since this coaxial cable does a good job in shielding unwanted frequency in or out.Hardly any useful pulse detected if connect the inner core to the pulse output.
I will be testing this theory of mine later which should work. :D
For testing i am using mere 10khz frequency which produce ringing frequency of 110khz at the 3 turns pickup toroid placed in the middle of 3 turns copper wire.
The output waveform pulse width is around 40ns at ~ 35Vpp across mere 3 turns pickup coil.In actual dally experiment later on the pickup coil will have lot more turns and repetition frequency needs to be lowered since inductance is increased.
Gentle reminder to all capable replicators  do take note all "kanapandze device" to Don Smith successful replication in China are making use of nanosecond pulse either via spark gap(Eg:Tariel,SR193) to high frequency nanosecond pulse.
I am just getting involved in this nanosecond pulse technology so please don't pop old lame question such as why no successful replication by others to date.
GeoFusion
Quote from: magpwr on February 23, 2015, 05:44:59 PM
hi Geo,
May i ask if you have made any further progress since your rather recent video which shows clamp meter on cable going to Earth which shows nice Amp reading.
Researching tesla coils projects i found that the use of "interrupter" circuit like 555 does indeed to increase the break out sparks produced from the top of tesla coils.
But i did not spot anyone in the internet perform any current clamp measurements from bottom of tesla coil to earth after the use of interrupter.
If length of spark increases which also means the "counterpoise" to earth grounding would also be increased.
Hi magpwr.
Nice uploads of the testings of the Nanosecond generator :), keep it up, only thru experimenting we will know.
Well to be honest I haven't touched it ever sins the last vid upload.
Yes, I also searched the internet if someone was showing this method with flyback too but nothing.
Further experimentations with this system will continue and is very interesting :)!
Yes with the amp clamp it's interesting results, but we will need to try it with analoge meter see any differences.
The interrupter method is awesome to work with but the Spark gaps become very fragile to tune.
Ofcourse if sparkgap length increases If Very high voltage discharge, the more output it would build
  but yet there is this Peak you can reach when adjusting SG
for the right resonance, of my own experience. almost the same thing when tuning tesla coils with SG's for better output
But What i'm missing now is a good HV caps with nanofarrad range capacity (fast discharge rate high voltage).
, Which are coming and Will be using of od the Mosfet drivers of Akula you also saw befor in pics I uploaded.
  Guyz,
The Idea of these devices is also to Let the discharge rate of the capacitor that is being charged by pulses to be so fast,
that it would flash the light bulb lets say as example 1000 times per second or faster nano seconds as they say sometimes,
it would seem in our eyes that it is stable light lighting up , but infact it's going on and off ultra fast, so our eyes wont really know.
Reminds me of the vid of Vasmus too when the lights flikker when tuning resonance from low output to full output..
Try to understand this text guyz! it's of importance!! but will need and antenna to do this! ;)
But will continue on the ruslan/Akula device with the circuit too. I have my kacher/tesla coil set and grenade
and try Get the same effect happening with that system,
that is the key and resonance with coil and caps. and the right frequencies.
there are Nikola tesla patents and drawings in his memo with these techniques of using ground.
But this idea came to me ever sins I saw Kapanadze's video of the green box and some of akula systems alot of nikola tesla memo reading.
made me understand how the ground system works and wanted to try out and never expected such results but awesome :P.
Nick,
Nice picsof setup working ;).
Ed morbus
thnx for that schematic :) it's all ideas for the test.
Someone had to do it right XD lol.
Will keep you all updated , been busy and with HHO devices, but All these things are keeping me away from
testing the other systems, so have to make time for them :)
Patience my friends.
Cheerz~
br549
magpwr:
Very nice job on the Nano-pulser Circuit. I just started working with the gernade coil so I am way behind most of the researchers. I am trying to understand if the nano-pulses are to provide excess electrons / ions, of if they provide magnetic pulses at a particular time to induce some effect on the nuclear level. It seems that a some opinions are that something has to occur right after the peak of the lower frequency wave generated buy the yolk driving the gernade coil. I am going to continue to experiment with the gernade coil for a while to try and gain better understanding. When and if I get to the next level of working with the high voltage, I think I will try your nano-pulser if it works out ok for you.
I have attached a diagram for my experimenting setup and a couple of short vids. of the first test.
Which have generated more questions than answers. :'(
Any and all constructive feedback is welcome. Lord knows I need it. :-\
https://www.youtube.com/watch?v=xWOSBFn78-w
https://www.youtube.com/watch?v=HA5dCZR8cUw
As always: Have a great day
br549
lost_bro
Quote from: br549 on March 01, 2015, 05:15:37 PM
magpwr:
br549
Good day br549
Noticed that voltage is Lagging current by *about* 90 degrees on your output inductor.
ELI the ICE man:      Current always lags Voltage by 90 degrees in a *pure* inductive circuit.........  so something is happening.
I would assume that the spikes are directly related to your MOSFET switching on the primary side of things.  Can't see your picture when writing this message but it looked like it's not ZVS, usually in resonance the wave forms match and the FETs are ZVS and then the inductive spikes/ringing all but dissappears.... in other circuits anyway.
take care, peace
lost_bro
EDIT*** just looked at photo again, and it looks close to ZCS on the Blue current waveform.
