0 Members and 542 Guests are viewing this topic.
lost_bro
Quote from: magpwr on February 28, 2015, 08:43:40 AM
Gentle reminder to all capable replicators  do take note all "kanapandze device" to Don Smith successful replication in China are making use of nanosecond pulse either via spark gap(Eg:Tariel,SR193) to high frequency nanosecond pulse.
Hi Magpwr
What ever happened to your replication of the Chinese replication of DS?  I remember that you were working on it about a year ago.  If you have a chance I would like to discuss that with you.
take care, peace
lost_bro
MenofFather
MenofFather
One guy, who made selfrunning use that schematic http://realstrannik.com/media/kunena/attachments/1180/Topruslan7.gif
How he say, he get overunity, then kacher work on 1.79-1.81 megaherc.
magpwr
Quote from: br549 on March 01, 2015, 05:15:37 PM
magpwr:
Very nice job on the Nano-pulser Circuit. I just started working with the gernade coil so I am way behind most of the researchers. I am trying to understand if the nano-pulses are to provide excess electrons / ions, of if they provide magnetic pulses at a particular time to induce some effect on the nuclear level. It seems that a some opinions are that something has to occur right after the peak of the lower frequency wave generated buy the yolk driving the gernade coil. I am going to continue to experiment with the gernade coil for a while to try and gain better understanding. When and if I get to the next level of working with the high voltage, I think I will try your nano-pulser if it works out ok for you.
I have attached a diagram for my experimenting setup and a couple of short vids. of the first test.
Which have generated more questions than answers. :'(
Any and all constructive feedback is welcome. Lord knows I need it. :-\
https://www.youtube.com/watch?v=xWOSBFn78-w
https://www.youtube.com/watch?v=HA5dCZR8cUw
As always: Have a great day
br549
hi br549,
Due to the time zone difference between Europe and Asia i can't respond soon enough. :)
After Hoppy have uploaded an image as attached i think i have made wrong move since the beginning of kapanadze experiment.
Base on my memory reading nearly all the Tesla document as found in Russian forum sometime ago some of which base on old US newspaper article which i didn't know exist.
Please do not bother starting with receiver/kapanadze winding and it's pwm or pll circuitry until the transmitter which is the tesla coil is able to sent current down to earth path.
If we can't see current to earth just from transmitter then don't bother starting with receiver.
I just got an rough idea in my head on how this is actually possible.At around 20KV onwards on the top surface of tesla coil there would be ionization taking place.
Now i am aware there was no  research being done if tesla coil is able to push current to earth using clamp meter to verify once the collapsing field of ions around coil returns back to tesla coil and to earth in the form of longitudinal wave.
If you do basic research on earthquakes you will know the longitudinal wave from the shock travel the fastest and the furthest via the earth and do some damage way before actual impact is felt from transverse wave from the center of quack.
The question is what are the options available in order to cause tesla coil to generate longitudinal/compress wave in the form of "current" to earth.
1)Applying interrupter is something like gated pulse coupled together with existing circuit which is running at resonance of tesla coil.
2)Applying nanosecond pulse which is pulse at a repetition rate which falls under one of the subharmonics of the tesla coil resonance frequency.
If you are using a clampmeter do ensure it produce quick refresh to display value .
Related to my nanosecond generator circuit.
Merely by changing IRF840 to APT10035LLL .I have managed to reduce current to 0.078Amps at 12volts.Do take note this 12volts is stepped up via 2Mhz voltage booster circuit running at around 90% efficiency.
At 5khz repetition rate the power drawn from battery is mere 1watt.
AT 15khz it's mere 0.13Amps x 12volts.
Using APT10035 the input gate pulse is reduce from around 150ns to around 100ns.This reduce current and it does increase output pulse voltage. :D
I have attached the 900Vpp pulse and nearly pulse 100Vpp pulse detected via the 3 turns ferrite this time.I am using 10pf i think 500volts or 1kv rated in series to 3 turns  copper wire.
Yes this nanosecond generator can be powered from 9volts battery as well if repetition rate is kept below 20khz.
