0 Members and 256 Guests are viewing this topic.
magpwr
Quote from: lost_bro on March 01, 2015, 11:55:24 PM
Hi Magpwr
What ever happened to your replication of the Chinese replication of DS?  I remember that you were working on it about a year ago.  If you have a chance I would like to discuss that with you.
take care, peace
lost_bro
hi lost_bro,
I replicated something which at the point of time which i was not so familiar with nanosecond pulse.In the forum salty citrus merely mentioned narrow pulse.
I have completed the variable DC 150volts to 1600volts generator(prototype) youtube "sanjev21" but my 7.2KV CREE IGBT switcher needs to be rework.
The optocoupler FOD3180 is prone to failure and lowest pulse i can achieved is only 200ns at 220khz.
I need to go lower like around 100ns.
I have attached my largest PCB every created. ;D ;D ;D
The green toroid merely provides isolated 33volts to all the 7820 regulator for  FOD3180 circuit.
Hoppy
Quote from: magpwr on March 02, 2015, 11:17:29 AM
hi br549,
After Hoppy have uploaded an image as attached i think i have made wrong move since the beginning of kapanadze experiment.
Base on my memory reading nearly all the Tesla document as found in Russian forum sometime ago some of which base on old US newspaper article which i didn't know exist.
Please do not bother starting with receiver/kapanadze winding and it's pwm or pll circuitry until the transmitter which is the tesla coil is able to sent current down to earth path.
If we can't see current to earth just from transmitter then don't bother starting with receiver.
I just got an rough idea in my head on how this is actually possible.At around 20KV onwards on the top surface of tesla coil there would be ionization taking place.
Now i am aware there was no  research being done if tesla coil is able to push current to earth using clamp meter to verify once the collapsing field of ions around coil returns back to tesla coil and to earth in the form of longitudinal wave.
If you do basic research on earthquakes you will know the longitudinal wave from the shock travel the fastest and the furthest via the earth and do some damage way before actual impact is felt from transverse wave from the center of quack.
The question is what are the options available in order to cause tesla coil to generate longitudinal/compress wave in the form of "current" to earth.
1)Applying interrupter is something like gated pulse coupled together with existing circuit which is running at resonance of tesla coil.
2)Applying nanosecond pulse which is pulse at a repetition rate which falls under one of the subharmonics of the tesla coil resonance frequency.
If you are using a clampmeter do ensure it produce quick refresh to display value .
Yes, the missing link is the transmitter, which is why I've been plugging away saying that Kapanadze is only showing half the setup in his videos. There has to be a remote transmitter with grounded output as Tesla clearly shows. Hopefully, this will encourage experimenters to concentrate on the injection of energy into the ground rather than from it. As to whether an overall energy gain will manifest at the receiver output, remains to be seen.
lost_bro
Quote from: magpwr on March 02, 2015, 11:39:03 AM
hi lost_bro,
Good day Magpwr
I saw your 150-1600v generator last year on your channel..... I guess that we are the only two people in the world who are attempting to replicate it.
The FOD3180 opto-driver has a propagation delay of  200ns max. propagation delay and 30ns max pulse width distortion.
When using multiple units in synchronizing mode (ie: attempting to turn & off simultaneously) these inherent delays will make the task all but impossible for ns timed events.
Salty Citrus used an UC3825N which generates an 50% D/C signal going to three GDTs, running each of three sets of Two Cree SiC mosfets in Series.  Total of 6 SiC mosfets in series.
Here is a qoute from Salty Citrus translated to English:
'Emphasized, MOS in series with the equalizing and drive are very important, especially the synchronization of the drive signal, the drive signal rise and fall time should be as short as possible, so that the switching time difference will be short conducive High frequency operation of the module, the stability of the whole circuit is critical.'
From what I gather concerning the timing and frequency of his system, is that the reference is to the Rise Time and Fall Time of the Pulse.  I was under the impression that being generated by the UC3825N it would have to be a 50% D/C as per Telsa's experiments in Colorado Springs notes.......
"This is by revelation "Tesla Spa Diaries", Tesla gives the optimum drive mode resonance Frequency of the circuit is approximately 230 kHz."
Salty Citrus "Sea of Energy Forum 2013"
See attached drawing from Tesla's Colorado Spring Notes... by Salty Citrus.
I have attached photos of my 500-3000VDC three switch flyback HV generator, I completed it about a year ago but have not had time to finish the project.....
Let me know if you have further information regarding the ns pulse concept applied to the Salty Citrus DS replication,
take care, peace
lost_bro
eugene900
Quote from: MenofFather on March 02, 2015, 07:48:41 AM
One guy, who made selfrunning use that schematic http://realstrannik.com/media/kunena/attachments/1180/Topruslan7.gif
How he say, he get overunity, then kacher work on 1.79-1.81 megaherc.
thank you for that link(drawing)
Void
Latest on Akula. Explains how Akula got all his new test equipment and tools.
Akula appears to be a very smart guy. Looks like he and his partners are currently looking for investors.
I feel quite dumb that I haven't been able to make a self running device yet. :)
Latest Akula video:
https://www.youtube.com/watch?v=6cSXYeGsO9o
Published on Mar 4, 2015
FREE ENERGY DEVICE - AKULA Blue LED Light Generator
During his studies the Russian inventor "Akula" had the idea to use the Earth's magnetic field as an energy source.
The inventor completed successfully a degree in radio engineering and microelectronics.
When he repaired a TV for friends, he saw for the first time a useful effect. Then he developed a power electronics device based on this effect, where he used special ferrites.
The first successful experiments were done in 2004, but the prototype did not run stable.
To develop the technology further, costly measuring devices were necessary, but because of lack of capital, he put the project aside.
In 2013, the cooperation with the German partners began, and the required measuring instruments were purchased in order to make the project a success.
In the summer of 2014, the inventor brought three working prototypes to Germany.
These were reviewed by numerous experts and companies.
After the start pulse of a battery, the circuits are running stable with durable performance.
The power output was depending on the prototype ranging from 0.5 watts to 1.0 Watts.
One of the prototypes was even shielded with a Faraday cage and stored overnight in an underground bunker to confirm long-term use.
One of the prototypes was dismantled on camera and in the presence of some experts. This video is viewable on the Internet.
See here: https://www.youtube.com/watch?v=2cqk7fijGG8
For the system commercially available components are predominantly used, but they are electrically connected in a special way.
The main concern of further development is the composition and production of the ferrite core.
This technology is stationary and portable and scalable to larger power outputs , up to 50 Watts per module.
See: https://www.youtube.com/watch?v=sPAz8aR1Ylg
This unique technology uses the earth's magnetic field like a spring, to generate an induction in the conductor from the prototype.
The prototype gives off the power permanently.
The advantages of this technology are the decentralized, autonomous, fuel-free and environmentally friendly use.
The major challenge in the development of this technology was to structure the Earth's magnetic field so that it can be converted to usable electricity.
Therefore, the Earth's magnetic field is like a treasure chest that gives off energy in abundance for the human race.
The use range is from a "5 watt flashlight " to a mobile 10 watt charger for mobile phone applications and versatile self-sufficient energy solutions for households, trade, commerce, and
industry applications.
Principle of operation:
To start the device a battery is used, which can be disconnected after a few seconds.
The power output is then immediately available for the consumer.
The excess power of the system allows autonomous operation – without a battery - or any power circuit - and supplies electrical energy to supply other electrical circuits for the consumer.
We are currently looking for investors and licensees who can advance the project with financial strength.
All the best...
