0 Members and 37 Guests are viewing this topic.
Void
Quote from: NickZ on March 12, 2015, 03:51:33 PM
   What do you think about this hand held oscilloscope?
   Would I be able to use this unit to match up the right Kacher to the grenade coil frequencies?  Looks nice, but only has one channel, anyways, just let me know what you think.
http://www.ebay.com/itm/3-5-Display-Pocket-Oscilloscope-QDSO-Bandwidth-40M-Sampling-rate-200M/221195783961?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20131003132420%26meid%3De03efbdb62eb4bb3a43c103a0570fd34%26pid%3D100005%26rk%3D2%26rkt%3D6%26mehot%3Dpp%26sd%3D160675899205&rt=nc
Hi Nick. It is not too bad at all for the price and features, but it appears it only comes with
a x1 probe, which means you won't be able to measure very high voltages with it. If you can get a
extra x10 probe for it that would be better.
All the best...
bringdownthezog
Quote from: Enjoykin on March 09, 2015, 10:37:33 PM
Aleksei Komarov Etheric Lantern
Based on Patent of famous Russian Inventor and Researcher Pavel Nikolaevich Yablockov from 12 October 1877 - Patent № 120684. Patent name "System of Delivery and Amplification of Earth current by atmospheric electricity from independent current cource". Current output at load is last 2 times bigger than current at input. Confirmed by France Academy of Science and leading France researchers of that epoha.
Goal is in special construction of assymetric capacitor (not electrolitic). Inner (smaller) plate of capacitor must be connected to source and outer (bigger) on load.  Good variant are many Layden jars or Tesla types assymetric capacitors.
This is great news Enjoykin. Thanks for sharing.
I found Aleksei's build of this device and I have to say it is incredible.
Void
Quote from: bringdownthezog on March 13, 2015, 01:26:01 AM
Hi bringdownthezo. Do you have a link?
All the best...
magpwr
hi everyone,
I made 2 interesting discovery related to current flow to earth from transmitter or kacher.
Earlier in the day upon changing the pulse width to around 52ns which one of my 74HC132 oscillator gates in  the interrupter circuit is running at around 10Mhz.The tuning is very tight
any changes the current flow to earth just drops to around 2mA and the other way round the current going to earth drop steadily.
The maximum current achieve to earth in the above configuration is 0.14Amps while current draw at 12volts which boosted to around 17volts battery is mere 0.35Amps.
No scope probe connected to circuit during measurement.
At this moment i am just using simple circuit tip41c with 10k pull up resistor between base and collector.I merely got 0.1Amps but bulb lit brightly at 12volts x 0.67Amps draw.
Next stage i will using part of Akula old circuit IRF4905 to try pulse the positive supply to kacher with nanosecond pulse.
My aim is to achieve the explosive discharge pulse to earth which would yield the high Amps readout at the "transmitter" end.
Once this is achieved only then this device will tested as fully assembled unit with the receiver portion which we have been wasting our time to date.
Keeping fingers crossed if i reach that final testing stage. :D
Ed morbus
magpwr thanks for sharing your findimgs
