0 Members and 39 Guests are viewing this topic.
Hoppy
Hi Mag,
Its good to hear that you are making some interesting observations on the transmitter to earth pulsing. I've been out of thinks recently with a broken leg but hope to get back to some experimenting in the next week or so. Could you please provide a fairly detailed schematic of your current setup, as I cannot understand exactly what you are doing. I certainly feel that you are working along the right lines by concentrating with working on the transmitter.
magpwr
Quote from: Hoppy on March 13, 2015, 08:28:20 AM
Hi Mag,
hi Hoppy,
I do wish you get healed soon.
I have attached the modified interrupter base on earlier experiment.
The gate oscillator is running at around 10Mhz which generate pulse width of around 52ns and this is combined with 566khz signal generator.In both case 50% duty.
Opps i made a mistake it should be the other circuit with the 100k trim pot which is connected to the gate with signal generator.No 10k resistor was installed in actual experiment.
Take note at 566khz the pulse width is 1766ns and combine with 52ns(around 1/34th the pulse width of tesla coil at resonance) this is where i got maximum current flow to earth at around 0.14Amp(10Amp settings in multimeter) at around 0.35Amp at 12volts which is boosted to 17volts.
Take note my test tesla coil resonance frequency is actually 566khz but 220volts 5watt bulb don't get lit since i am after maximizing current flow to earth.
Please do not use scope probe as it would tamper with reading.
My latest findings with IRF4905 which is pulsed at positive supply revealed nothing much except it does produce noise at the top of tesla coil if screw driver is near.
220volts 5watt bulb does get lit at lower current draw from battery at around 0.42Amps.
Maximum sound achieve at the tesla coil top is achieve at 139khz(Roughly 1/4 frequency of 566khz) at 80% duty since my mosfet driver TC44551 is the inverted version to IRF4905 which need to see negative to turn on.
For this experiment 74HC132 was not used but just the simple common npn transistor circuit for tesla coil.
To wrap it up for today my discovery revealed there is relationship with amount of voltage going in to kacher or tesla coil to the current flow to earth."Counterpoise difference increases with higher voltage"
Next stage of experiment(After some planning in my head)-
The only way i think to get to see explosive pulse discharge in Amps to earth might be to apply nanosecond pulse to the primary coaxial(one of the 2 wires in coaxial,outer for nanosecond and innner for kacher circuit) winding of tesla coil while it is still oscillating.
This will be done switching mosfet eg:IRF840 or APT10035LLL at around 52ns pulse width via 1k resistor from (+) to limit current from the capacitor bank 400volts.
This is the one of the way pulse repetition at high frequencies can be accomplished.
Void
Quote from: magpwr on March 13, 2015, 09:22:32 AM
Hi magpwr. It is normal to have a current flow to an earth ground from both a tesla coil and also
from certain kinds of radio transmitting antennas. Also, yes, a higher voltage will result in higher
current flow as well, since this typically translates to a higher input power into the tesla coil/antenna.
Since this is normal, then where does the over unity come from? It seems there has to be more to it than that.
High power vertical radio antennas can have quite a high ground current, so they will run out a whole array of
ground radial wires from the base of the antenna to act as a ground return to reduce ground current losses, to improve
the efficiency of the antenna, since earth ground itself can be quite lossy. The higher the voltage of your tesla coil, the more ground
current you should see, but again, that is normal for a high voltage tesla coil. Where the over unity comes from remains a question.
All the best...
Hoppy
@ Magpwr,
Thanks for the additional info on your experiment.
@ Void,
Yes, you are quite, there will be a current to earth via capacitive coupling on any Tesla coil setup. I assume that Magpwr understands this but has nevertheless observed something unusual relating to the relationship between input current and earth current? It would help to see his measurement points on a full system schematic and test equipment used.
magpwr
Quote from: Void on March 13, 2015, 09:53:31 AM
All the best...
hi void,
I know it is a tough question to answer.But if i don't experiment at all then i shall never know."Learning is for life"
Maybe the longitudinal wave to the earth via explosive pulse discharge may provide some clues in due time hopefully.Maybe it helps in the ringing of the device as a whole. :o
At 17volts supply i got 0.14Amps to Earth using 52ns pulse.But what would result be if i pulse 52ns into coil with around 400volts.
If i am really lucky in my experiment at this voltage i might get to see around  3Amp (0.14Amp x (400/17)) to Earth. :D :D
At this stage i would only be half way completed.
