0 Members and 210 Guests are viewing this topic.
Void
Quote from: Enjoykin on March 20, 2015, 07:39:32 AM
Good news from Russia folks !!  :D
NEW OU confirmed by Rik - 300 W output with near 0A input current. All trick is in bucking coil configuration on old TV ferrite joke core. Device need very precise timing and fine tunning. Tunning is very difficult. Don't try without good oscillograph and signal generator. To catach effect power supply must be minimum 30Vdc. Mosfet VDS=min 600V/20A. Coil: 16 sections - each 35 windings - 0.2 mm - magnet wire. How to wind look at picture.
Very bad news was: Forum trolls have done their dity job and Rik has escaped - forever.  >:(
On all forums same dirty story. No more comments.
Rik from realstrannik.ru
http://realstrannik.com/forum/svobodnaya-energiya/258-rabotayushchaya-ustanovka-s-kpd-ot130.html
Hi Enjoykin. Looks interesting. Thanks for posting this.
All the best...
magpwr
hi Enjoykin,
This link you  gave seems to be related to "Rodin Coil" by itself powering mains bulbs.
Yes the effect are indeed interesting but it is not related to Dally or Kapanadze device.
In the meantime i am just gathering some PLL circuit  since i am a  noob related to high input voltage tesla coil be it 220khz or 1.5Mhz.
Somehow i do have this fear of tesla coil at high voltage around 200VDC or 400VDC since most of us would know the meaning of RF burns firsthand using low voltage below 50Volts. :D :D
Time for me to invest in variac locally for remote turn on and at the same time thinking of hacking a 12-220v inverter to reduce duty cycle so that output can be made variable. ??? ???
Managed to get basic Antenna base PLL circuit for tesla coil working but for low voltage 12volts.Current to Earth achieved 70mA with the use of interrupter at 4046 pin 5. :'(
NickZ
    I had at first made the Akula type yoke coils (primary and secondary coils), on top of a fully wound yoke, which had already been previously wound using 28 gauge magnet wire.   But, at one point I heard the inner magnet wire coil shorting somewhere to ground, but with a hell of a lot of power. Not like what the normal 12v input would produce.
This was a hint to me that lots more power could be had IF the yoke coils are place on top of a much finer wire coil, (including this fine mag wire coil below them).
But, when I wound a new yoke, without the mag wire fully wound below the two primary and secondary coils, I forgot all about that effect, as I never saw it again...
  The picture below is showing that same yoke coil, wound with mag wire, which I later used to wind the akula type yoke primary and secondary coils on, but leaving the mag wire coil below them intact.
  Showing a 60 watt incandescent, and a 60 watt CLF bulb, both partially lit, using 12v, and a single transistor  modified Joule Ringer circuit.
magpwr
hi everyone,
I have made 2 new discovery today by using my 12volts battery ~0.24Amps boosted to "30volts to 1kv 10ns Nanosecond Generator" which the output is connected to Multimeter "10Amp setting" in A/C mode.
The output of Multimeter is connected to Earth.
At 20khz repetition frequency for nanosecond generator the current to Earth is around 230mA and at 55khz repetition the current to Earth is at 0.5Amps.
My findings the higher the frequency the higher the current flow to Earth provided it's is pulsed at nanosecond at say 1kv as an example.
I am closer in finding out how around 4Amps current measurement via clamp meter to Earth is achieved as demonstrated in Vasmus and Ruslan and i think Akula.
At this point i am now a firm believer in transmitter current transfer to Earth is one of the most important requirement in order to get this device to self run.This is still a work in progress.
I have attached my photos to show the current reading to earth.
Latest update 0.9Amps to Earth at 100khz pulse repetition 1kv 10ns.
2nd stage of experiment to test for presence of longitudinal wave using avramenko plug to led.
Since i am living in a high rise apartment the only earth i got is water pipe -stainless steel.
2nd discovery for today upon touching AV plug to water pipe in any part of the house i am still able to get Led lit.This is the best discovery i have made to date prove the existence of longitudinal wave.
Reading up some article i am already aware that longitudinal wave travel on the surface of metal conductor.
So Radio frequency is out of the equation since Avramenko plug is not in proximity to the transmitter source and take note my water pipe is the earth.
I am aware metal water pipe is connected throughout the country.PVC pipe is never found outside any home especially the water distribution network.
I have attached a photo of my AV plug which is touching the water pipe in the kitchen which is some distance away from my room.
Next stage of experiment to find out on how to properly apply nanosecond pulse via interrupter to tesla coil and at high voltage around 150volts to 200volts DC.
This clamp meter demonstration to Earth to show current movement as shown by Russians isn't fake at all.It is just that we are really naive that's all.
