0 Members and 675 Guests are viewing this topic.
magpwr
hi Geofusion,
Latest update related to my experiment to obtain 1 wire current flow to Earth(Myth to Reality v2.0)-
The 2nd part i will show everyone the Tesla link which describe the effect we were getting using digital Amp or Clamp meter on 1 wire to Earth using pulse or via spark gap.
I have obtained 1.5Amps current flow to Earth merely using 1 wire.
This time i have intentionally increase maximum repetition frequency for my nanosecond generator from 100khz(0.9 Amps to Earth) to 700khz(1.5Amps to Earth).
I did have not design  this circuit board for use with APT10035 hence i did not install a heat sink yet.
The screenshot which show my nanosecond generator with the scope probe connected do not produce high current reading to earth since my scope is not isolated from the electrical earth.
Since i have accidentally destroyed 2 3Amps sk surface mount diodes on both my voltage booster circuit i am forced to stick with 12volts battery for time being.
The maximum frequency achieved at 12volts is 700khz for my IXDD614 driver in the nanosecond generator circuit.Take note the output voltage is mere  200...300volts using 12volts 0.7Amps.
1.5Amps to Earth-
Mica capacitor is mere 10pf 500volts which is connected to nanosecond generator output to digital meter at 10Amp setting then other end of meter to earth-water pipe.
For those whom are knowledgeable the nanosecond pulse is able penetrate the dielectric layer which for example can be mica or even air capacitor(Huge winding over multilayer coil)
I have attached screenshot-
Part 2-Nikola Tesla free energy: unraveling Greatest Secret(Device to Harness Free Cosmic Energy Claimed by Nikola Tesla)
http://www.nuenergy.org/nikola-tesla-radiant-energy-system/
For the inexperienced the content in the above link would hardly make much sense related to what Geofusion and myself have achieved which is related to 1 wire current flow to Earth. :D :D :D
Condense version of what i have spotted base on the above link which makes sense related to what i have achieved  recently.
The Earth's Electrostatic Charge-The earth has a charge of 96,500 coulombs. With a potential of 360,000 volts, the earth constitutes a capacitor of .25 farads (farads = coulombs/volts). If the formula for calculating the energy stored in a capacitor (E =1/2CV2) is applied to the earth, it turns out that the ambient medium contains 1.6 x 1011 joules or 4.5 megawatt-hours of electrical energy.
In order to utilize this high-voltage energy you must do two things — make an energy sink and then devise a way of making the "sink" oscillate.
Zero Point Energy-Do read up the paragraph
New strategy -I will need to find a simple way to breakdown the air dielectric layer between the high voltage which is present at the antenna and the multilayer coil which is connected to Earth.
My last kapanadze experiment using the coaxial which was loosely wound over multilayer coil without kacher  and by connecting 1 output from nanosecond generator which create alot of interference in my PLL pwm circuit.
The positive outcome was there is current flow  <0.5Amps to the earth.
Without nanosecond generator activated-
Using 0.47uf x 2 in parallel the maximum voltage i got on my not true RMS meter was 259volts A/C.This only after i placed 0.1uf x 2 in parallel across 220volts 60watt bulb.
The circuit is inefficient since it's running at around 14.8khz for a Air core.
I am gonna follow Akula's advise base on old MenofFather Russian translation not to go lower  than 18khz.At 1 x 0.47uf the frequency i got is around 22khz  but the output is mere 190volts A/C.
Ed morbus
NickZ
    Mag:
   I'm still wondering if the amps to ground readings are really accurate. For example, what can that current actually do?
Will it light a bulb?
   Here (below) is another pulse modulator circuit. Can this be connected to a Mazilli driver for the grenade/yoke adjustments of frequency and duty cycle? It can work with push-pull Induction Heater circuits, like the Mazilli, and there are several different units available. But, they are more expensive, and not TL 494 based, like the ones from China.
  What do you think?
   http://www.rmcybernetics.com/shop/PWM-OCm
   I've also been thinking of buying this USB 20mhz scope with the 100x probe, for $100. Link below.
It also has AC coupling which some other scopes of this type don't have.
It should work with XP,  I hope, but I'd rather have one that can connect to my 10 inch tablet, instead.
  Any advice is welcome.
  http://www.amazon.com/SainSmart-Portable-Handheld-Oscilloscope-Bandwidth/dp/B00FYGEFYM/ref=pd_sbs_indust_1?ie=UTF8&refRID=1NTTCV9P946JQTFYYW9K
lost_bro
Quote from: NickZ on March 26, 2015, 01:52:48 PM
Good day NickZ
Yes, it will light regular AC light bulbs.
I will take a picture tonight of one on my *experiments* where the ground current lights up a 100watt AC bulb to full brightness.
Don't have the pics on hand, so will have to take new ones.
The ground current is real current and will run light bulbs no problem.
take care, peace
lost_bro
Hoppy
Yes, its real current but the ability of a digital meter to read this current accurately is questionable.
