0 Members and 675 Guests are viewing this topic.
verpies
Quote from: NickZ on March 26, 2015, 05:06:51 PM
  As I found the modulator circuits listed on the Induction Heater (Mazilli circuit), I'm still wondering WHY the linked PWM units can't be connected to a Mazilli, to control it's duty cycle, and frequency. Please explain.
Because the Mazilli is a zero voltage switching circuit and when these zero voltage crossings occur is determined by the LCR parameters of this circuit - not by an external PWM switch.
magpwr
Quote from: verpies on March 26, 2015, 09:27:52 PM
hi verpies,
It's been a long time.Respect to you for being one of the early members whom started this kapanadze topic.
Not surprised just small handful of people became impatient along the way and started throwing stones at you indirectly.
"They were just having high hopes from the start that such device can be bought like a kit from a electronic hobby store nearby." :D
PWM can't be applied for mazilli but it can be modulated onto existing frequency which is already running at L/C resonance.
Solution just install 1 IRF4905 p-channel mosfet at the positive say +12volts then both 240ohms...470ohms resistors connected to drain of IRF4905.
Applying high frequency to gate of IRF4905 we can merely "superimpose high frequency" onto the existing resonance frequency.
NickZ
  So then, can anything be done for the Mazilli type circuit (induction heater/push-pull oscillator) to be able to use a PWM or similar type of ready made pulse modulation device, to control frequency and duty cycle?
Or, is the use of tuning caps at the yoke's output the only frequency tuning option?  As I suspect.
  As I have several of the IRFP260N fets,  I can build a different driver circuit for the yoke/grenade/Kacher coils, if need be.
I'd like to keep it as simple as possible, first, just to observe the effect of the right combination of pulses, voltages, and so forth.
  When tuning the grenade for a higher output frequency (which does not make the yoke ring). Like 22khz or higher,  the output at the bulbs is not as high, as at the audible ringing levels. There is also frequencies that make the yoke core vibrate strongly, especially with the addition of magnetite magnets placed on the yoke at the right spots. The yoke is the power house of my circuit, and so far the addition of the grenade and Kacher circuits to it, or the two 37.5 meter earth ground lines, haven't made much difference to what just the Mazilli/yoke combo can do by itself to light several 100 watt, 120v  bulbs.
magpwr
hi everyone,
This is the youtube video of Geofusion which also assisted in providing inspiration for one wire current movement to Earth.
I have attached circuit layout of Geofusion on how to achieve the 1 wire current movement 1.5Amps to 4.1Amps to Earth.This is a easy experiment to conduct to prove the existence of current movement to earth.
The spark gap acts like a nanosecond pulse.
  https://www.youtube.com/watch?v=n3hU5CCBt5k
(Just skip to half way onwards into video)
The attachment by Hoppy which showed the 1 wire transmitter and 1 wire receiver by Nickola tesla made me realized that i have started this kapanadze experiment the wrong way from the start.
We have been focusing on the receiver portion all the way without any thoughts on the transmitter current transmission to Earth.
Just look at the top half of image and merely disregard the 2 wire receiver to Earth since we are merely interested in 1 wire receiver from the Earth.
There is relationship between voltage and frequency in order to see higher Amps related to 1 wire current to Earth experiment.
For Geofusion experiment assume flyback transformer estimate resonance frequency base on my memory is around 14khz.
But it's HV output  of flyback  eg:28kv would exceed tesla coil/kacher at similar supply voltage eg:24volts.Hence it is important to apply higher voltage around 150volts for kacher\tesla in order to generate higher potential.
For my experiment i am able to see 1.5Amps because i am using higher frequency 700khz but low voltage <300volts.
If low frequency is used say 17khz to 37khz(repetition rate of nanosecond generater as obtained from pwm circuit before switching power to bulbs) the voltage needs to be higher in order to see high current movement to Earth.
Take note nanosecond pulse as applied by electronics or via spark gap is the way to achieve the 1 wire current movement to Earth.
The only disadvantage of spark gap is the repetition rate can't be controlled easily.Fine tuning is needed and this won't last long as the spark gap becomes corroded.
This is my unproven theory on why the antenna of telsa coil is placed over multilayer coil.
Once the transmitter send current down to earth via 1 wire.At this instant if my theory is correct there would be a sort of vacuum created surrounding the antenna.
The vacuum or void created at the antenna would allow the 1 wire receiver to pull whatever current from the ground in burst to sustain oscillation/power.
"This is where i recall one of the device creator bluntly mentioned explosive discharge".
It would be easy to solve 1 problem at a time hence we just need to focus on the transmitter portion first via kacher to obtain amps without worrying about synchronization or receiver coil for now.
Scope a must.It can be a one time investment for lifetime without worrying too much about 1 time shipment cost.
Cheap alternative UT136B <$30 with free shipment is able to measure frequency in the 2 Mhz range even remotely in the case of kacher.
Hoppy
Quote from: NickZ on March 26, 2015, 11:46:56 PM
Nick,
Yes, the caps are used to 'tune' the Mazilli. You could also modulate the frequency as described by Magpwr.
