0 Members and 589 Guests are viewing this topic.
NickZ
  Bat1Robin2:
   I'm working only on the Ruslan version of the Akula second video device.
  The tuning cap that is in series with the 3 turns coil is a 0.47uf, about 600- 2000 volts. I use a 0.47uf 275v, that I had on hand, as I don't get higher voltages from that part of the crt.  But, higher the voltage on these caps the better.
  The 0.1uf cap in parallel with yoke/grenade 168 turn coil, I'm not sure what voltage Ruslan is using there. But, you may need to use more than one of those caps to adjust for resonance.  That is probably why he does not specify the voltage, nor amount of caps needed.  I use 0.1uf, about 275v, and two more tuning caps at the bulbs.
  The bridge diodes may be IN4008, or the UF series. I just use two diodes, on my flyback core for the feed-back circuit. Which now produces over 12v and is connected back to the input.
  Two 12v, 7ah batteries in series can be used to run the circuit for testing. I find that a single 12v battery is just not enough voltage to be able to hit on the highest resonant peaks, and to be able to reach the proper running frequencies. At least in my case.
  The ferrite rod is used to tune the Kacher's output frequency and to intensify the current, to the antenna coil, and should be used.  Any old radio has one.
It may work without it, but not as well.
Hoppy
Quote from: NickZ on April 02, 2015, 10:51:05 AM
  T-1000:
   Sorry but, I don't buy the idea that these devices are based on nuclear decay. What is the proof???  Just Akula's opinion?
No tests were done for radioactivity, and Geiger counters won't work properly on HV systems, as you know.
Nick,
I agree, no proof at all, just opinions. My opinion is that none of Akula's messy demonstrations convince me that he has anything that does not rely on a conventional power supply to supply his load.
NickZ
  Except that Tiger was a witness to the Akula device, and did not see anything to indicate a fraud. If you can trust that source...
   I personally don't care where the energy is coming from, so long as it lights my bulbs, and is not causing harmful radioactivity to be spewed in my house.
Hoppy
Quote from: NickZ on April 02, 2015, 12:14:44 PM
He's playing the same game IMO. In cahoots.
NickZ
  Maybe, but time will tell...  those aren't my feelings though.
