0 Members and 938 Guests are viewing this topic.
Hoppy
Quote from: NickZ on April 04, 2015, 06:15:40 PM
  Hoppy:
  One earth ground line is the one that is being connected to the old radiator that has been buried in the ground, with one wire coming out from the dirt, to which they connect to. The other ground line is going to the faucet water pipe, where it is tightened it up with a pair of piers.
  These systems don't always have to comply with the exact same bulb brightness as compared to the 220v grid source.
  My question would be: Why do they need to use the 12v to 220v "converter" to provide 220v to the circuit.
  Akula also supplied the yoke secondary coil with rectified 220v, (300+ volts possibly), from his power supply, on his first device video.   Something to think about?
Nick,
Please see my last post that has been edited.
Maybe to light the lamps from a concealed power supply.  ;)
NickZ
  Oh, what hidden power source?  You mean that all those guys that are holding all the components in the air, are blind to hidden sources, as well.
Tesla coil in the trees, or in the Lada parked in front, ground loop from grid source?   Common Hoppy... it ain't faked. Get a grip.
cheappower2012
To Nickz
There are 3 different readings taken,one is an attempt to measure the ac voltage across the lights
this resulted in the digital meter cycling,its caused by pulses in the ac,caused by the setup.
Theres a ground current reading,this is a false current reading created by the Tesla interface,
mixing pulses with the 50hz ,220 vac.The cheap clampmeter used has a defect that under these
conditions creates a false ground current reading.I have a clampmeter made by the same company as the one used
it has this defect.Then theres the current reading of one bulb then 2 bulbs,the translation helps
as theres no close up of the reading.The point is theres a very good chance that it is outputting 5,000 watts.
As to why theres the ac inverter its more a show,he could have built the looping internally
as in other devices.Its to show that the device is in a looped self running mode.This
device is the guts of the 2004 device in a green box
the resonator is hidden in that one too,in a can,aking.21 has talked to Tariel
a lot,Tariel told him theres a special component he makes or modifies
that makes this device work only he knows how to make it,this is why people will
fail if they try to replicate it.As I have said many times it is not a Tesla invention
nor related to anything Tesla invented,Tariel says its a Tesla invention to send people
on a wild goose chase,I believe its an accidental discovery by Tariel.The term resonator
is used by Tariel to fake you out,its an active component,in every device its hidden
except in the aquarium 2 device.As you have pointed out it is very hard to put on a demo
in front of a large group of people and fake them all out,as some will be skeptical and look real hard for fraud.
I don't believe its impossible to replicate, but its very,very hard to figure out enough correct information to replicate.
NickZ
  Cheappower:
  Resonator hidden in the box... well maybe, but  I don't think so. It needs to be wound on the same core as the grenade, or how will it resonate with anything. Or possibly is not an absolutely essential part of this type of device.
Akula used a resonator coil on his first and second video device, and did not hide them at all, so does Ruslan.
So I don't think that is the "secret".
  The only thing that I can accept is that the 5 1000 watt bulbs are lit, and the device self running. Regardless of current measurement, which look like they are all incorrectly read by the amp meter.
Ruslan can read his output with a multi-meter possibly because his output has been rectified to DC, or for possibly another reason. But, I can't.
  That's where I'm at right now, rectifying the output to DC, as I can't read the output on any meter, even without the Kacher being connected.  I still don't understand why they rectify the output to DC to run AC bulbs, but, I'm going to try it anyway, to see what happens.
Bat1Robin2
Are we talking about the ruslan device?  The power supply is a 220 input to 24 volt output.  I also think the reason for rectification is because of the high frequency output would not work well in the standard power supply and may not light bulb properly. look up skin effect.  Different metals will have a different skin effect for example iron is .008 mm depth at 10 khz. I dont know what the skin effect of tungsten (filament light bulbs) would be. But not good at ultrasonic frequencies. The reason for the low voltage converter is to run the electronic chips they wont operate at 220v for sure they are integrated. Whats the confusion about? Looks like 2 sources of input high voltage & high current using higher frequencies allows the air coil mixer to operate but must stick with copper at that stage due to skin effects issues. The 2 fields should mix in the grenade in phase and resonant. So the special transformer is multiplying the electric field times the magnetic field for output. Then rectified to be able to be used with the ferrite transformer cores in the power supply and the tungsten in the bulb. Then finally brought back down to low voltages to run the integrated circuits again. The concept is clear getting it to work is the problem seem like there are a lack of successful replications.  So the goal is to provide 2 fields to the air coil grenade 1st one is high voltage field (tesla) 2nd one is high current field (3 turn output somewhat like a spot welder design).  In phase Thats why tesla pulse on top of the yoke 3 turn output sinewave. I wonder if we could use an audio amplifier to drive the yoke windings dont want to blow my amp but just wondering, has anyone tried that?
