0 Members and 594 Guests are viewing this topic.
NickZ
Quote from: Bat1Robin2 on April 04, 2015, 11:19:33 PM
Are we talking about the ruslan device?  The power supply is a 220 input to 24 volt output.  I also think the reason for rectification is because of the high frequency output would not work well in the standard power supply and may not light bulb properly. look up skin effect.  Different metals will have a different skin effect for example iron is .008 mm depth at 10 khz. I dont know what the skin effect of tungsten (filament light bulbs) would be. But not good at ultrasonic frequencies. The reason for the low voltage converter is to run the electronic chips they wont operate at 220v for sure they are integrated. Whats the confusion about? Looks like 2 sources of input high voltage & high current using higher frequencies allows the air coil mixer to operate but must stick with copper at that stage due to skin effects issues. The 2 fields should mix in the grenade in phase and resonant. So the special transformer is multiplying the electric field times the magnetic field for output. Then rectified to be able to be used with the ferrite transformer cores in the power supply and the tungsten in the bulb. Then finally brought back down to low voltages to run the integrated circuits again. The concept is clear getting it to work is the problem seem like there are a lack of successful replications.  So the goal is to provide 2 fields to the air coil grenade 1st one is high voltage field (tesla) 2nd one is high current field (3 turn output somewhat like a spot welder design).  In phase Thats why tesla pulse on top of the yoke 3 turn output sinewave. I wonder if we could use an audio amplifier to drive the yoke windings dont want to blow my amp but just wondering, has anyone tried that?
  end quote.
    Well, for one thing why anyone would think that a 220v Ac to 24v DC power supply would NEED a rectified DC voltage of over 300v, for it to work properly. And also, why 220v high current AC bulbs would NEED 300+ volts DC current,  as I had mentioned previously.  As there is no problem lighting AC bulbs using AC voltage with my device. Nothing to do with skin effect
  The concept may be clear to you, but only a few people have been able unravel the mistery of it's effect generation.
  Another point is that there are not 2 frequencies to be heterodyned, but there are three different frequencies. As the real power is coming from the magnetic output of the yoke 28 turns coil, along with the grenade's 168 turn grenade output coil. Which is also an inductor, and not just the output coil for the 2 other frequencies. If I run my device with the 3 turns coil circuit disconnected, I see no or very little difference in the output. The bulbs shine at almost the same brightness. This indicated to me that my Kacher to the grenade 24 turn inductor (resonator coil) are not in sync, yet. And as I have not been able to sync them up properly, using tuning capacitors, etz... the windings turn count on the 19m, or 12m, or 9m resonator coil are not correct, at least not for my set up.
As I have several tap points on all my inductors, I'll be testing these different tap points to see what difference that can make.
Hoppy
Quote from: NickZ on April 04, 2015, 06:31:35 PM
  Oh, what hidden power source?  You mean that all those guys that are holding all the components in the air, are blind to hidden sources, as well.
Tesla coil in the trees, or in the Lada parked in front, ground loop from grid source?   Common Hoppy... it ain't faked. Get a grip.
Like with all good magic, its important to keep the audience occupied in the 'safe' area. No wandering around the stage.  ;)
NickZ
   They were wandering all over the place, looking at the trees, looking at the road, looking at the ground, looking at the Niva, looking at the power lines. But, no one located that strange illusive transmiter that can light up 5000w of incandescent bulbs from a distance.  Maybe it's due to Ruslan's radio tower, and they are all in cahoots.  Ha, ha...  Too bad we weren't invited.
Hoppy
Quote from: NickZ on April 05, 2015, 09:45:40 AM
They were his security team making sure nobody wandered into 'sensitive' areas.  ;D
