0 Members and 557 Guests are viewing this topic.
NickZ
    Hoppy:
   Good to know, but I can't run the device long in any case, due to the fet issue. I do use the 12v 10amp battery charger sometimes as well, just for testing purposes.  Although it takes no time for the Mazilli to eat up any battery's charge, at 300 to 600 watt or higher draw. But, the idea is to either make it more efficient to run off of solar power, or, ideally to run itself.
   Even the induction cookers circuitry like Igor Moroz uses, can output 2000w or more watts to his bulbs, while drawing only 500w.
Meaning that it may be possible to even use a solar array of 500w, and obtain and output of 2000 through the circuit, and/or  also feed some of that power back to the grid.
Bat1Robin2
hey nickz,
What capacitor are you using for C15 on the schematic. The capacitor near the Yoke drive FET.  The schematic just says 1 ufd. On some of the videos it looks like a disk ceramic maybe. Can you specify what you have there for capacitors. (type, voltage and size & connections)? (non polarized i assume?)
I have a polarized  1ufd electrolytic at 50 volt or so.  I do not feel like that is right. It looks to me it is acting more a a spike absorber than anything else. Any comments would be helpful.
Thanks
squire42
Hello to all fellow experimenters, been watching this thread for quite some time now and also trying to relpicate Akula/Ruslan type devices with much interest.  As I am pretty ignorant of most things, this is no different but came across two patents that may be related to this field.
One is Philo. Farnsworth - Electron multiplier
http://www.radiant-powered.com/downloads/patents/US2221473_philo_farnsworth.pdf
Second is Lelsie Kent Wanlass - Parametric Device
http://www.radiant-powered.com/downloads/patents/parametrics.pdf
Some similarities between these are mixing of two frequencies.  With Philo's seems an electrostatic field vibrating at a high rate mixed with a lower frequency is the principle there.  With Lelsie Kent's device, seems harmonics with a fundamental frequency mixed with a double frequency. (child on a swing pumping at both maximum peaks).  Looking up parametric resonance on Wikipedia, seems to have some effects that could be interesting to harness.
Here is a quick video showing the kacher having a good effect while mixing with the yoke.  Higher frequency super imposed onto a lower frequency.  No COP >1 but the effects are very interesting and needs more study.
https://youtu.be/4oEYvhonWxo
Parametric definition according to Google:
Relating to or denoting a process in which amplification or frequency conversion is obtained using a device modulated by a pumping frequency, which enables power to be transferred from the pumping frequency to the signal.
Quote from Parametric Device Patent :
When properly constructed such parametric circuits are essentially self starting oscillators whose oscillations build up to a certain amplitude and then remain constant at that amplitude.
To all the experimenters and back shed tinkers, your work is important and inspirational  to many, breaking new ground takes hard work and 'out-side the box' thinking.  Thank you for taking the time to share your adventures!
Sorry if this has been posted already and may be a step backwards for some but thank you for taking the time to read this.  Good day to all!
NickZ
  Well, I don't know if Igor's set up can be called an overunity device, but maybe.
  It has not been a self runner as yet though, however the idea was always to loop it.
  He bought a new induction cooker, after the first one burnt out.
  The induction cooker circuitry may incorporate some type of pulse modulator or controller, as well.
As it's pretty involved, but relatively small in size. And it needs no big Tesla coils, or big grenade coils to work.
  Comparing the magnetic induction circuits output to normal grid output, may not be the best way to look at it.
  But, it would be a very useful device if self running were obtained. So far, no cigar...
