0 Members and 1004 Guests are viewing this topic.
GeoFusion
Hi guyz :),
Yes, Akula is Ligit to the core, and Ruslan also, he replicated some of his tech, but also really doesn't understand how, but somehow does though.
good guyz and awesome in experimenting yet they have mission to complete on earth as how Tesla did in his time.
Many others have devices, but same concept but different ways of utilization. :)
This vid was posted once, But will post it again , shows how lighting coming from ground and go upward, this can kill doubts about the ground
wire. :)
https://www.youtube.com/watch?v=RDDfkKEa2ls
We all have a chance to see these devices to work and help with the ideas.
And some of us to Replicate them and guide others too build it too.
So we all can have it freely around even if it lights up 1 bulb, for light around you.
Because when you have it
back again for a while , Just saw Akula's most simple circuit ever build to self run, this is worth while having just to understand how he does it.
https://www.youtube.com/watch?v=L4Q8Mr2kCck
Enjoy guyz :).
Will keep you all posted.
magpwr
Quote from: Bat1Robin2 on April 06, 2015, 06:06:23 PM
Nickz,
I am using the UF4007 per someones advice.  I dont really think they are heavy enough to handle very much of a load but its a start for me. I just figured we would need high speed diode because khz frequency. I have made a change in my connection of the s1 in the schematic because the way it was sending a higher voltage than logic level down to the Tesla driver board and damaged a protection diode. also it did not invert the signal the way it was, now it does. I can have pulse on top or bottom depending on switch position. I think this will help aid in getting the pulse on top of the yoke signal so many windings it is easy to reverse the polarity on one. I agree scope is a must no way around it. I noticed my Tesla ringing frequency is 1.25 Mhz. When i reduce the number of turns on the top load it brings it to around 1.6 Mhz. Which is much closer to where my grenade resonance tested about 1.7 Mhz. I need to order a Power supply for testing i think i will get the 0-30vdc 10 amp. adjustable protection. 68 dollars on eBay.  That will be enough power right? I have not powered my yoke fets more than a few seconds so far because i am scared to death something will blow sky high. since i only have heavy duty 18volt battery and fuse, with no caps yet. So far for me i can power up the tesla circuit and the output will slowly rise to 230 or so unloaded then i can blink a light. no power to yoke yet only gate signals working good. i can post signal pictures if anyone is interested.
hi Bat1Robin2,
I have just read your post which contain the attachment which you have drawn a red line to input of IR2184 after the inverter gate.
You seem able to read and understand the circuit which makes it little easy for me to communicate with.
This way we are able to select if we want the nanosecond pulse to appear at top half or bottom half of sinewave across 0.47uf capacitor.
Do ignore other pll/non pll based circuits found where nanosecond generator is getting it's signal from dual channel output leading to the dual igbt's driver for yoke.
Reason being the nanosecond pulse will never be aligned at the very top or bottom of sinewave taken across 0.47uf capacitor base on my previous experiment.
There is something else which i have overlooked apart from the recent discovery that a current transfer to Earth is one of the most requirement as indirectly revealed by Tariel,Vasmus,Ruslan and Akula using clamp meter as found in video.
Latest discovery-
If you take a look at the circuit which you have edited.There is a capacitor of unknown value which is connected across 28 turns output from yoke core.
This was not implemented in any of our replication device yet.
I then recall in the old Akula circuit diagram there is a capacitor which was connected in the bifilar winding which i have attached and circle in red for reference.
I only got time to resume experiment and etc from Thursday to Sunday. :)
I have attached the Akula tesla coil tuning pdf which was typed by MenofFather in Russian base on Akula's video on harmonics,current to Earth.Also take note simple explanation from Akula on whywe should not go below 18khz for a air core multilayer transformer .
English google translated version is found bottom half of pdf.
The above translation is obtained from copy of old Akula video which was deleted-
stivep1 backup video-
https://www.youtube.com/watch?v=PPHipGkfSAY
Other small tips for the Yoke driver-placing ferrite beads on both gates of  igbts would produce nice square wave without even seeing any ringing ripples at all.
I am using just 1 amorphous beads but common ferrite beads can be used maybe 2 is needed at the gates if you are particular about having nice waveform while in operation.
But take note igbt's like to be driven at 18volts which near the limits of TC4452 at 15volts is fine but igbt will heat up easily even with cooling fan if power exceed 100watts.
I am using FGA25N120ANTD -1200 V, 25 A NPT Trench IGBT  for yoke\toroid driver although the commercial 1800watt 240volts induction heater i own merely using the 11Amp version.
Another good  IGBT which produce even lower heat at 15volts for gate signal is the 50N6S2  600volts igbt this is without inbuilt protection diode version.
Void
Quote from: GeoFusion on April 07, 2015, 09:27:52 PM
Hi GeoFusion. That video and device was not made by Akula, and the video was posted on April Fool's Day
by the guy who originally made the video. It appears to have most likely just been a prank...
All the best...
Hoppy
Quote from: Void on April 07, 2015, 10:29:38 PM
All the best...
I just cannot understand how anyone can take that circuit and demo seriously as a self-runner! :( Akula is clearly having an April Fools laugh. Having said that, he does not restrict this type of activity to the month of April.
Void
Quote from: Hoppy on April 08, 2015, 03:00:38 AM
Hi Hoppy. I guess you were maybe doing some drinking? ;) As I pointed out, that video was neither
made nor uploaded by Akula. It has nothing to do with him that I know of...
All the best...
