0 Members and 1116 Guests are viewing this topic.
GeoFusion
:) ok ok , I wanted to post it to see if you guys know about it, no Idea if it is not of Akula's but it seems to me real. but could be
faked. it all depends will not go on debate on that one ;).
magpwr,
Yes the Fuelless Akula generator is what you should try out and others if can, this one is dependent on the 3 turn on yoke in
series with HV Cap. Even if the system is not so 100% well, but still self runs, it can open up
many other Ideas and how other devices work.
It's a bit more simpler then the other ones, this one I'm also trying out too.
Yes the capacitor at the output Air coils, that one is necessary :),
my RMG system Also had Caps connected to a 25Turn coil shorted on the output transformer coils, it raised my output lvls
while trying it out, but adjusting the Resonance by placing caps and removing caps on the cap banks.
My observations and thoughts :) and willing to share;
In this case with the Fuelless Akula Generator, We keep tuning for the right Frequency of the pulse coming from the
IGBT's or Mosfets driven by theb TL494 or different , to reach the resonance between caps and Air coils for great output.
It's total induction/heat,  BUT the circuit pulses the output air coils like how a Tesla coil should,
but now with Bifilar coils and LC coiling. Remember just like a tesla coil but slightly guys . :)!
Nick,
About the lighting, is to remove doubts on energy particles around us that can be harnessed from the ground or Air.
It's the Idea.
The ones that jump from ground going upward (streamers ), yes they are are also reactions of the strike coming from above but,
It's not always the case, Remember to see the Ionosphere and earth and the space between where we are
as a huge Capacitor :).
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg445268/#msg445268
Ok guyz back to work
Cheerz~
NickZ
  Lari Man, has mentioned in his own post below the video, that it's a fake.
  Or, is he just faking us out... and it really real?  Ha!
  Geo:  I just wanted to make a point about the ground issue, as it's miss-leading to show that video,  as
if there is energy going from the ground to the air.  But, there isn't, it's an effect from the cause, the bolt from the clouds.
  Once we all disperse to make the different circuits, not focusing one anyone in particular,  not comparing notes, etz.  not much may actually get accomplished.
   How about we stay on the Akula second video replications, especially the Ruslan versions of it.
As that's the one with all needed schematics, videos on tuning, witnesses, etz...  The only one that was proven to work as is being shown, at least Akula's version of it.
  Tinsel:  The IN5408 diodes that I made into a full bridge rectifier overheat in one minute, and melt their solder points, when used at my grenade's output to the bulbs. Bulbs light about the same on DC, fets still overheat, as well, but it does change the running frequencies. I haven't tried to feed back that part of the rectified output to any other part of the system, yet.
I need to find the right rectifier diodes, to continue on with that.
Void
Lightning occurs because there is a large electric charge difference (large voltage difference) between two clouds
or between clouds and the ground. Sometimes lightning occurs between clouds, and sometimes between clouds and the ground.
Yes the Earth can hold a charge, but in order to make use of that charge you must have a charge difference. The charge can't
be used unless it has a charge difference to work against. With a tesla coil, you can create a large charge/voltage difference between
the tesla coil and the ground, but it takes power consumption to create that charge/voltage difference. But the process is worth
thinking about for sure...
All the best...
lost_bro
Quote from: NickZ on April 08, 2015, 10:00:31 AM
Good day NickZ
Try the *UF version* of that diode:  UF5408, or for that matter, any UF type diode with the correct Voltage rating.
There are *better* diodes (in as much as they can be heat-sinked) but they come in TO-247 packages:  DSEI 60  see attached pdf.
take care, peace
lost_bro
NickZ
  Void, Bro, and all:
   I've used up my supply of the UF series diodes on the bridge rectifier that goes to my flyback core for the feed back circuit to the input.
   There seam to be several feedback loops on Ruslans Akula 2 replications.
   I may have some of those other higher amp diodes and their heat-sink, I'll probably have to give that a try.
Thanks for the suggestion.
  That type of bridge is the same as what Igor Moroz uses to rectify his output to DC, as well.
  Have any of you made any of the feed back loop(s) yet?  With or without the 24v to 220v power supply.
  EDIT:
   Maybe something like these 1000v, 6A diodes might work.  I like the price, a buck for 10 of them, with free shipping.
http://www.ebay.com/itm/10Pcs-New-6A10-6A-1000V-Rectifier-Diode-chip-Cheap-/181561935023?pt=LH_DefaultDomain_0&hash=item2a45ef44af
   If I can wait a month for those diodes to get to me by turtle mail.
