0 Members and 363 Guests are viewing this topic.
Bat1Robin2
Nickz or anyone?
Hey when i power up the Tesla circuit over 15-20 volt or so all signals begin to get all trashy only nice clean ringings when at lower voltage. it seems the Tesla is spewing out (emi) everywhere are you or anyone else having these issues. I have put on some more filter capacitors on the power supply and tried to move the scope farther away but no help, still having trashy signals and the Tesla ring frequency right now running around 1.25 Mhz. Any ideas would be appreciated. I do have a nice pulse and ring down at lower than 12 volt or so to the Tesla primary supply. Did ruslan use opto isolation ic or what? need a better schematic this one i have been posting and working with does not keep the signals clean also the R28 still overheating even at 2 watt and only 12 volt input on yoke i think that resistor has to be lower value.
There is a video he has with no yoke being used at all. any information on that setup? I am noticing the ozone smell it seems to be coming from the yoke and the hissing noise, sounds a little bit like an old tv station static sound but at higher pitch. I can not get the logic level signals to stay immune from the Tesla interference.  There is a video where he shows the .47 x2 caps on the output of the grenade after the bridge diodes. Do you have another schematic?
Hoppy
Quote from: T-1000 on April 10, 2015, 07:59:50 PM
The problem with plain Russian is, they are given only know-how and not just instructions for 1:1 copy. Also if someone is thinking about Ruslan is making fakes - him spending more than year of his time with spending his money on parts and equipment, soldering circuits, winding coils is at least illogical...
Cheers!
Its not that he is making fakes from the outset, rather that he is genuinely trying to make self-runners but not succeeding. In the process of this he has got frustrated like many of us and has IMO resorted to staging a faked self-runner or two for the hell of it. It all helps the 'hit' rate for his many demo & tutorial videos, as he is clearly a guy who thrives on media exposure.
NickZ
    Bat1Bobin2:
   Although there are different schematics, they all show the 0.47 tuning cap. I use more than one cap for that, but as each circuit is a bit different, you'll have to experiment a bit to find which caps work best.  Remember that it calls for a 1700 to 2000 volt (non- electrolytic cap) there.  On some videos, Ruslan uses two or more caps there.
Remember to use a ferrite rod for tuning the Kacher, as that will also change the Kacher's output frequency.
   If the trashy signals are due to the Kacher signals, that can possibly be controlled by using a pot on the transistor to adjust the voltage. And an isolation transformer is shown on the Kacher circuit diagram, which is used along with some caps to avoid HV from the output re-entering the input to this driver circuit. You can also try to use a separate 12v battery, (or two, for 24v), that is  isolated from the Kacher driver circuit, and from the rest of the device, to test the difference in your signals.
  The response of both the grenade/yoke circuit and Kacher circuits and their running frequency, is dependent on the voltages used, along with the tuning caps, ferrite rod on the Kacher/antenna, ground lines, etz...
  Do you use a long (37.5 meter) earth ground line, as is recommended? Is the ground wet around the ground rods. If not, then let the water hose run on the spot for a while, and really soak the ground around it.
  What frequency is your yoke/grenade running at?  Can your 10x scope probe read the Kacher frequency.
I ask, because I need to know if I really need to order a new 100x probe, along with the new scope, or not.
So, if your 10x probe works to read the 1.2 mhz Kacher frequencies,  please let me know.
  I bought a new 12v 7ah battery so I could obtain higher frequencies from my circuits. Even to 24v, or so. As my circuits drivers really needs voltages over 15v to operate well. But, I got a defective battery, instead. I'll need to return it, from where I got it.  Minor set back.
  Bat: please upload a picture of what your current set up looks like, at this point.
Bat1Robin2
Bat1Robin2
