0 Members and 1921 Guests are viewing this topic.
NickZ
    Guys:
   This article (below) mentions that the Earth Resonant Frequency has changed from 7.8 to 16.5. hertz.
   I don't know if this has anything to do with how our devices function, or not. But, if there is an Earth resonance frequency that our devices are tapping into, this change in frequency may have some type of effect on the tuning of this type of Akula/Ruslan generators.
http://www.theeventchronicle.com/metaphysics/metascience/earth-ascending-schumann-frequency-resonance-of-the-earth-has-doubled/
  This thread, as many others, has slowed to a crawl.  Not too many people working on this and other projects lately.
Or is there???
tgraca
Quote from: NickZ on April 16, 2015, 09:36:26 AM
    Guys:
Or is there???
Thanks Nick. I am wondering if you got any overunity with this project. I haven't gotten anything close to OU. -t
magpwr
hi everyone,
I am beginning to believe that Akula is using some kind of capacitor discharge technique which would produce high EM Pulse at the Antenna which is in sync with the PWM or PLL circuit.
If anyone got a good memory would able to recall in one of the older Akula video where he used a bulb to test if the ferrite rod is able to produce spark.
I am able to get to see high voltage merely by touching HV probe to ferrite rod base on my experiment as mentioned below.
Warning This experiment i am conducting is not meant for the basic replicators-
This is my latest findings related to nanosecond pulse with ferrite rod with 5 Clock wise and 5 Anti clock wise windings.
Using the above ferrite rod with probe connected at the other end of rod  i observed there is increase in  output voltage from around 1kv vpp to around 1.48kv Vpp from the output of my nanosecond generator.
The another end of ferrite rod would be connected to Antenna /Outer Coil.Nanosecond pulse can be detected from the middle of the coil.
Do search for Eric Dollard Condensed Intro to Tesla coils.pdf.
Although the document keeps mentioning EMF which i think it should be some kind of info for a EMP generator related to this project. :D
NickZ
  Adding ferrite cores to most coils will usually increase the output levels, as well as the input current that is being drawn.
  Adding the 3 inch ferrite rod and it's inverse coils to the Kacher secondary will aid to make the HV spark stronger, and the impulse more stinging.  This is normal, but it doesn't mean that you'll see a higher output at the bulbs, unless all the frequencies are properly matched, if then.
   I have NOT seen any sign of overunity, nor self running, at least not yet. I've tried tuning my set up the best that I can (without a scope). But, even the guys that do have a scopes and other test instruments, and have both HV and as well as the induction (push-pull) circuit alined,  have not achieved anything to write home about. This is all a bit discouraging...
  Today, I'm trying to replace the new battery that I just bought with another new battery that works, as this last new one does not charge. And without at least 12v, and the 7ah output that it should have, I can't continue to tune my device.
I need more like 15+ volts to make the running frequencies work as they should. AS 12v is really not enough voltage, to hit the proper peaks, at least on my device.
a.king21
Quote from: NickZ on April 16, 2015, 10:38:27 AM
NickZ: You might find Gotoluc's videos on how to find resonance without a scope very useful.
https://www.youtube.com/watch?v=fQhvh3wd2I0
