0 Members and 2030 Guests are viewing this topic.
a.king21
.NickZ:  Also if you want to rejuvenate dead batteries cheaply her's a circuit to try:
Duncan's schematic:
http://www.overunityresearch.com/index.php?topic=2903.100
NickZ
  a.king:
   Thanks for the info concerning the neon bulb as a resonance indicator.  I've also been using them (neon bulbs) for some years now, along with several types of led indicators, multi-meters reading, etz....
  Now I'm also using the android sound oscilloscope, spectrum analyzer, and other apps on my tablet to look for best resonance point, and for adjusting the frequencies of my set up.  Analog scope is still on my list.
  I think that I must of murdered my InterState 12v, 45ah car battery, as it was working well not long ago, and it's only less that two years old.  Maybe it can be de-sultated and such. But, a dead cell, is a dead cell.
   I also just burnt out a 150 watt flood light, when running on my device for less than 2 minutes, (but, several times), and now it's all chard and black inside the glass, from the HV, or from what ever. My neon indicators bulbs also get all black inside if I leave then on the circuit.
  Bat1Robin:  Please resize your pics to the size of the one that shows your scope shot, as the first big one has messed up this thread. Until the admin sees it and changes the wide text size to how it was before that picture upload.  Thanks.
Thaelin
Nick:
   You need to down convert the HV to the rated voltage of the unit used. Will be loses \
involved tho.
Old news
Bat1Robin2
https://youtu.be/cMMjlOBg_iY
NIck,
My setup its not much but im working on it there seems to be some conflicting information and different schematics. I just got my filter capacitors in and sorry for the shaky video during the last few minutes.
I got a bulb to light yesterday only 20% efficient at this time. i am way off the mark somehow.
NickZ
  Batman:
  Now you are now seeing how a fairly simple concept can turn into a real challenge to get working, and even more so once you try to make it self running.
  Couple of things that I noticed from watching your video:
  First is that your yoke is NOT the right size, and you should look for the three inch ones (or bigger), and not the smaller ones like you are using. That size yoke you have did not work well for Akula, either.
  Second thing is, that your fets are not the bigger 200v, 50A ones like the IRFP260N.  Or the ones that Ruslan uses, like the 50v, 200A ones. I can't remember their number.  The small Fets will work at lower current levels, but will not give the same amount of gain at the output.
  The yoke signal is being interfered with by the Kacher circuit, instead of adding anything to it. That static sound does not sound right, either. That is possibly what you need to work on to match frequencies with the yoke circuit. If you give the Kacher more voltage that will change it's running frequency, which can cause interference to the induction circuit, instead.
What is the frequency that your yoke 3 turns coil is running at the tuning caps?
  The yoke circuit should not make any audible ringing noise, if it's running at 27KhZ, or so.
  I'm no expert at this and don't pretend to be one, but if there is something that I can help with, I'll be glad to oblige.
