0 Members and 105 Guests are viewing this topic.
Dog-One
Quote from: NickZ on April 19, 2015, 09:09:14 AM
   There is also a video by GeoFusion that shows the way to wind the grenade. You can look for that video on you tube, as well.
If someone can link it here, that would be great.  I went with this one for starters:
https://www.youtube.com/watch?v=f9djNfcKu3Q
NickZ
  I think that GeoFusion may have removed that video, as I can't find it anymore.  Or, maybe it's hiding somewhere...
  Ruslan's video is good enough though, however, notice how each one of his grenades, and circuits as seen on different
videos are built a bit differently.  Some have a 25,25 turn resonator induction coil, and some have 12, 12, as it is also different for when using 12v, or 24v. All in all it's a bit confusing.
  I think that the important point is the 37.5 meter size of the 168 turn coil, and 37.5 meter ground line. As the resonator coil, and Kacher coils, you may have to fine tune for best output using a scope, once all coils are connected to the long ground line.
Enjoykin
Quote from: magpwr on April 19, 2015, 09:59:31 AM
Yes i am little concern about the safety of my scope at this point on since the another unused channel is also picking up high voltage.
Hello Magpwr
Terminate other channels of your oscillograf with 50 oms non inductive resistors or simple ground inputs - isolate them. You have that possibility in setup mode of your Rigol. HF high voltage glitches you can stop by shielding your oscillograf. For example roll it in aluminium foil and ground shield. For viewing screen you can use fine metallic grid mesh. And move oscillograph min. 1m-1.5m from your tesla transformer.
If you have possibility you can buy old 10MHz,CRT lamp oscillograf  for High Voltage measurements.
Reg.
Enjoykin
magpwr
Quote from: NickZ on April 19, 2015, 01:48:27 PM
hi Nickz,
It's Monday early morning over here.time is short.
Yes the clamp meter base on the clamp metallic core is merely able to handle only around 400hz or 500hz sine wave for the typical low end model.
Few years ago upon building a working battery desulfator with 1 microchip i found that a given core even if designed to handle 1khz can be operated at higher frequency if the pulse width is kept very narrow such that the core won't be saturated even at high frequency.
This is why the clamp meter is able to pick up the current spikes since the pulse width is in nanosecond range.
By placing a 1...3 earth wire loop on test ferrite toroid since i was using a thin wire 2.5mm sq electrical wire for starter. I am sure the high current produced in the Amp range to earth would able to light a bulb if it is stepped up and rectified.
12volts Battery current consumed 0.5Amp but spike to Earth was at 9amp...5Amp.Sound like a joule thief for low voltage but high current which i designed few years ago with 25mV input.
That's it i got to go.
Dog-One
Ruslan posted a new video:
https://www.youtube.com/watch?v=XPL7bq5fs4w
Third harmonic is important and it also looks to me like he hasn't quite yet mastered the grounding.
