0 Members and 31 Guests are viewing this topic.
Bat1Robin2
Geo fusion,
I am using 800 ohm 7 watt resistor on the bemf  R26 back to power supply as schematic shows 1k ohm but wattage not labeled. i believe that bemf power is being used by the tesla circuit but im not sure. 1/4 burned out and 2 watt blackened , 7 watt goes to 140-150 degree but holding with my smaller fets its doing ok. so i recommend higher wattage until it holds.
Hoppy
Quote from: GeoFusion on April 20, 2015, 11:55:54 PM
Hi there Guyz  ;)
Finaly got my vid to be uploaded, and was busy today on the bench to see some
amazing effects. there is still so much more to try out but Thoughts are welcome and help.
https://www.youtube.com/watch?t=156&v=aOSkep6jZnA
Bat1Robin2, Nice setup, it's going in the right path but see if you can get your hands on
IRFP260's or IRPF450's or better :) . but awesome results thought ,Keep o experimenting!.
And yes, Give the both Yoke and Freq generator individual power supplies, or sources from one core.
Driven by another TL494 or different ;) , giving thoughts.
Lost_bro,
You are thinking how I had it in mind a year ago :) , Using SSTC or DRSSTC type driver circuits , It's basically that but reinforced.
Nickz, yes I still have the Vid on my channel, it's there for the view :) , check it out, But I have learned from the Ruslan Vid completely
that is how I managed to build the coil and using the schema too.
magpwr, try my Flyback experiment with a coil setup :) !, but not with 12 or 24Vdc, but with +100Vdc, and us the ground. and good
HV caps, there you will see results, I have made a High power Mazilli, that can handle those voltage ratings and yes there is more power
and yet dangerous high voltage acs to ground., this is done with 12V battery connected to inverter  and rectified.
Let me know if you guyz want the schema of the circuit. I did post it some time ago ;)
cheerz
Hi Geo,
Its good to see that you have now built the PWM push-pull module of Akula's setup.
What current are you drawing from the 24V supply?
Tip: You need some decent wire connections onto your lamps.  ;)
NickZ
  Geo:
   Thanks for posting your video.  Can I ask you where you obtained the 1000w bulbs?
  Those new bulbs seem to put out less light (lumins) than your round core test lighting the 1000w halogen bulb:
https://www.youtube.com/watch?v=QRBI39us0VI
  Which had used the Royer crt and the yoke core back then.  But, you couldn't keep it lit more than a few seconds, without burning the fets.
  And so far it's also giving less light compared to my current set up, which is running off of only 12v, or less.
  So, I'm still waiting to see the "awesome" results,  when you connect it all up to the grenade and Kacher, and get it self running.
Dog-One
Quote from: Bat1Robin2 on April 21, 2015, 12:16:12 AM
The attached circuit most certainly works and I also agree you need R26 to handle all the reflected power fed into the toroid when the secondary is unloaded.  I'll order some TWM10 resistors and see how things behave.
Funny to think how a simple power inverter can bog us down so easy.  Hopefully we can get past that and start exercising the grenade coil.
T-1000
Hi,
I had conversation with Oleg (who made circuits for Ruslan) yesterday and he shared some links to forum (pass through Google translate):
http://realstrannik.com/forum/dosae-initiative/228-foreigner-skhemy-2-2.html
http://realstrannik.com/forum/ustanovka-kulabukhova/213-skhemy.html?start=108#9074
His nickname in that forum is Foreigner, you can ignore other people there.
Also here is offline copy of his circuits and PCBs:
http://filebin.net/84mauc7noc/Kapanadze_replica_-_Ruslan.zip
Hopefully that helps with electronics part.
Cheers!
