0 Members and 83 Guests are viewing this topic.
Bat1Robin2
Quote from: NickZ on April 21, 2015, 06:14:16 PM
  Bat1:
  Remember that to obtain 70% efficiency, your bulbs would have to be the same brightness, as when when they are run on the grid.
  Now, Ruslan is using a two transistor Kacher circuit, as each new crt is different from the previous one.
You must be confused efficiency is the output/input power .. nothing to do with bulb brightness. i can have 1 bulb on really bright at 50% efficient but light 4 bulbs medium brightness calculated at 70% . i measure output current and voltage DC and then compare to input voltage and current DC. no funny waveforms straight dc. I totally ignore the wattage on the bulbs and there brightness they are not accurate until 120 is reached. i think we agree just in different words. How can anyone do this project and not measure input vs output?
I have sent a few pictures. Im afraid the hard reality of output is always less than input is hitting me right on the calculator screen. The tesla seems to enable the output somehow but nothing more than addition of the 2 input sources. i will try to increase tesla supply in the next few days but i have already noticed the supplies dont like to be separated somehow the bemf from the yoke helps the tesla or vise versa. look at the pictures and notice that when the tesla spike happens it actually stops the drive input on the yoke half way thru the square wave drive i believe this is what causes the current to reduce in the power supply. since most of the power is feeding the yoke cutting that drive signal off early is what helps reduce input.
Bat1Robin2
closely look at picture 13 drive signals only no power to FETs
Then look at picture 16 with bulbs in background and how it cuts off the drive to the yoke exactly when the yoke spikes.
Bat1Robin2
sorry i mean right at telsa spikes. its stops the yoke fet for the rest of that square wave. ok im done posting for a while sorry.
Tomtech29
T-1000 Thank you for your support for a long time already and there was no sign on here alive.
-a lot of interesting information, I think that this time the scheme is closer to the truth?
(I'm only bothering diagram which introduces a lot of confusion and lack of measurement synchronization center)
magpwr "here is a little of truth no matter how to perform a security gate of the power transistor (IRFP260)... soundproofing signal through the varistor zener diode combinations? there comes a point while tuning and gets a kick mortal!.
hello forum participant  "Bat1Robin2" I do not know where you got these readings,I did not see how to fix your configuration LC series circuit if you could throw a link to the video,I know that when you have a lower tuning frequency of the inductor is needed to sync while we choose one of the harmonics at high frequencies where the Tesla 1,7Mhz when you turn on the pulse peaks spend Kacher I think that in a short time Ruslan show us how they look pulses I run and greet all.
NickZ
  Bat1 and All:
  Remember to resize your pictures.
  What I see on my set up is that unless the Kacher is in sync with the induction crt,  the addition of a ground line or feed-back path onto the rest of the circuit, won't do much.
  On the other hand, if and when they are in sync, then you see that the addition of the Kacher it will not disrupt their superimposed signals, but will aid it instead.
   Adding the ground line(s) will only add to the circuits output when the two circuits are in sync, or close to it. Otherwise little to no improvement will be noticed. At least on my device.
  I don't think that neither Akula or Ruslan are comparing the input levels to the output readings when tuning. Nor have I heard them talk about that, as an important factor. Plus, it may not be dependent on that at all, for their devices to work in a self running mode.
