0 Members and 52 Guests are viewing this topic.
NickZ
  I just uploaded this last video of mine, showing some of the effects of the use of ferrite from flyback cores, in aiding the system to achieve some lower forms of resonance. I need more voltage to hit better resonance points. I'm running the yoke crt on a 12v, 10amp car battery charger, (maybe putting out 7 or 8 amps). And a separate 12v, 2amp input to the Kacher crt, in order to avoid some of the HF interference, getting back into the Kacher driver.   I'll also be going back to using only battery power, soon.
  https://www.youtube.com/watch?v=vGCj-IE2Eig
T-1000
Quote from: NickZ on April 22, 2015, 07:13:42 PM
Nice setup, just noticed you are probably missing http://en.wikipedia.org/wiki/Automatic_frequency_control circuit to keep it on resonance no matter what load or inductance change is applied.
The Oleg's circuits I posted previously are all about that for yoke and for Tesla coil with resonance tracking of both generators...
NickZ
    Thanks, T-1000:
   Yes, I totally agree that automatic voltage and/or frequency regulation is very important. For now I'm just looking for the effect, but will have to incorporate most all of the other items later to make this into a useable device. Like when Oleg sells US some boards. Ha!
   My progress is slow, very slow, but steady. And the time that I spend tuning and adapting and experimenting with my own hands, is enough of an experience in itself. Also, practically no cost has gone into this device, no expensive gear, no scope, etz...
More than a year has gone by since I began working on this type of devices,  seams like yesterday.
  If it takes a few more years...  so what.
Bat1Robin2
Nick,
Good to see bulbs being lit, nice work. you will soon see no matter what caps you use , no matter where you put that Tesla pulse centering wise, no matter how good of ground you get no matter  what frequency you use, you will not get over 70-80% efficient. Because i have already tried it battery does not help tried that today same as power supply from grid. You can feed back all you want it will not help every bit you feed back will only be returned at 70-80%. And dont put too many caps on your power supply it needs to fluctuate with the bemf. I see the brightening effect the Tesla has . The Tesla brightens the bulbs and decreases the yoke drive at the same time but not to an over unity level. I can hear your drive frequency is still unstable as the hissing noise in the video. When it runs at the right load for your drive it will be almost silent. unless you go into audio range on the drive frequency. Scope and generator would bring you to see the truth very quickly. Scope shows unstable frequency as you move in and out of resonance along with the hissing noise. Generator would allow you to move all thru the spectrum of highs and lows. I am so impressed that you were able to get to where you are with no scope. Honestly i would have never made it without a scope. Good luck in your ground pumping theory, still seems possible to me but not with this design. only very small changes in output with or without ground and i have an 8 foot rod right into the lake bed with a large wire 40Meter or so. just as design says. i have tried 1 to 5 bulbs all frequencies covered 25k-50k several pages of data on my notebook with efficiency numbers. several days spend ranging thru with cap changes and such. i have seen up to 6-7 amp on the 3 turn output. But again efficiency 72% is best i have seen. Im sure someone can press it up to 80% pretty easy since i am a real amature transformer maker.
NickZ
  Bat1:
   Yes, well, good luck with your next project.  I still have a lot to work on here.
   It does not surprise me that most of the replicators on this project have given up.
   But, I'm still very much into it.
