0 Members and 529 Guests are viewing this topic.
yg_34
He says he is using signal generator to create magnetic field and  with pulse generator he is amplifying this magnetic field to increase efficiency. He is using 24 V 8,3 Amp power supply . He says it may be pulling more than 8,3 A but it is not getting hot. He says, he can not measure current directly from power supply since there is magnetic field arround although he decreased by grounding.
NickZ
   TomTech:
   Thanks, that is an interesting video, and one that I had not seen.
   I don't know what is going on, either, as he has a whole different set up, and is using a pc UPS, as his power source.
   But, he can light the 1000 watt bulb, although I don't think that it is more than just an inverter system, with no feedback loop nor self running, as yet.  Yoke ringing shows that he is running at under 20khz, as it can be heard, and is very piercing to the ears.
   Until he can get it to self run, without a UPS, signal generator, or batteries, we don't know if this is a useful device, or not.
magpwr
hi everyone,
This is my first test of my revised winding without Kacher activated since it's transistor burnt out due to over heating.
The bifilar winding which is connected to 3 turns of toroid/yoke have changed to nearly 100 turns consisting of 4 layers of approx 25 turns.
As expected this solved the issue using just 1 x 0.47uf capacitor since there is higher impedance due to nearly 100turns (Akula)this time compared to 50turns for the Ruslan design.
This cause the PLL circuit of mine to auto lock to 27.xxkhz with 0.1uf HV capacitor connected in parallel with 60watt bulb 220volts.
I have attached power consumption and scope shot.
The output of the HEF4046 is connected to a prototype dual channel output PWM generator (74HC132) set at 40% duty.
Kacher and EMP generator(4.8kv using 12volts 0.5Amps running at 25khz repetition during testing stage) to Antenna testing will be reserved for weekend.
Hoppy
Quote from: NickZ on April 23, 2015, 04:51:47 PM
   Well, I hope that you do get that boat up and running.
   I have seen enough to know what I'm looking for, and will do my best to find it. One way or another.
   As you can see, all the guys that went looking for greener pastures,  are still looking.
I'll peep in through the porthole to see how things are progressing from time to time.
Best wishes,
Hopeye
Tomtech29
 :)yg_34 thanks for the translation you're cool and that's a dumb work  everywhere to push but not want me there ;D
- I read it 25x 4 times, each winding 25 This frequency 27 Khz is not fit me but it's ok with you.I have some 24x2 on a single winding it around 37Khz and on both 21kHz. So I assume that the greater the number of windings frequency drops but still it does not affect the power output of not Erase?
I did not check what will be the scope for 25x4 ...
