Tomtech29
how you connected directly? the output of the coil grenade 60Watt. bulb and the measurement of channel 1 on the capacitor in parallel?
without the use of 28 of the winding core.
(27.xxkhz with 0.1uf HV capacitor connected in parallel with 60watt bulb 220volts.) ? ...why capacitor with bulb-
NickZ
  Some of the diagrams are showing that the two yoke secondary coils are going to separate coils, with no connection between them. And other diagrams, like this one from Ruslan (below)  showing that there is a connection at the 0.47 cap, between the two coils.
  I don't see much difference between doing it one way or the other.  Well, maybe just a slight improvement when they are both connected up in that way, as Ruslan has it.
  I also tried adding more winds onto the 12, 12 turn inductor (resonator coil), but it did not seam to help. I'm using 24 turns now, and an input of 12v, or so.
Tomtech29
we have so C2 (0.47) of the above series resonance circuit with conditioned grounded,ground reference point has a phase ratio,remember the direction of the inductor coil is to be against the direction of the grenade.
so the measurement of the capacitor C2 have the reverse phase of 180 degrees.
the aim is to formulation of the sine wave without increasing power consumption losses (less current flows through it and be strong tension)
So C1* is relatively reverse process in short C1*selected so that one could get the best value at the output of strengthening,I could be wrong,A feedback capacitor (high-pass filter?
I think that the reason there is also a semiconductor (diode) VD1. not know the answer It's a secret Forest(Processes-processes) ;)
Enjoykin
Хочу поделиться:
Так как подходящего куска феррита у меня не нашлось, собрал дома всё что было, сердечники дросселей из блоков старых телевизоров, фильтры блоков питания, в общем всё, что не ушло вовремя на на помойку,  далее взял лист плотного картона (подошел один из рекламных буклетов в почтовом ящике), свернул в трубку 10мм диаметр, длинной 220мм. Феррит с помощью молотка и массивной латунной пепельницы получилось превратить в порошок (на превращение ушло дня три), который был просеян  через кухонное сито для муки, максимальный размер фракций получился не более 0.5 мм. Одним словом, всё это добро было засыпано в трубку, ровно по центру протянул толстый провод, вдоль всей трубки, сам провод на всякий случай дополнительно поместил в термоусадку, трубка после тщательного простукивания и утрамбовки феррита была закрыта прокладками и залита парафином с двух сторон. Намотал две катушки, мотал бифилярным способом, последовательно, соотношение первички и вторички на вскидку взял 1:20 и сверху всего этого добра высоковольтный автомобильный провод 7 витков который соединён с центральным (сквозь феррит) на землю. На первичку подавал переменку 12В ток 1,5А (понижающий трансформатор 220/12 после которого два транзистора два конденсатора две пары сопротивлений по схеме электронного ключа открываются около пика фазы питания, номиналы подбирал экспериментально, пришлось таким образом заменить генератор прямоугольных импульсов), на выхлопе вторички получил около 190-230В (тестер к сожалению цифровой стабильно не показывал) при нагрузке напряжение просаживало до 130-170В (нагрузка лампа накаливания 220В/75Вт) ток вторички 0,1 -0,15А нить лампы едва краснела, и то заметно только в потёмках. Далее искрил куда только можно и как возможно, опишу лишь положительный результат. Высокое добывается ТВС 110ПЦ15 с первичкой 10 витков проводом сечения около 1.5-2 квадрата лакированный (марку провода не знаю) блокинг-генератор одно-плечевой (один транзистор один конденсатор два резистора 5 витков вокруг первички обратная связь, думаю кто в теме поймёт что это за схема). Сразу скажу, тупо искрение непрерывной искрой ВВ ВЧ на всевозможные выводы ни к чему не приводят (эффект незначительный), результат наблюдался лишь в случаях когда питание блокинг-генератора было подключено через автомобильное реле, управление которого в свою очередь было подключено к переменке 12В, что питало первичную катушку генератора (надеюсь понимаете о чём я, на всякий случай поясню: пик фазы переменного тока в первичке включал реле, питая блокинг-генератор и вырабатывая высокое высокочастотное напряжение. Далее спад фазы отключает питание высокого, при следующем нарастании тока цикл повторяется). Самый яркий эффект наблюдался при подаче высокого на внешнюю катушку из высоковольтного провода (7 витков), которая далее подключена через центр феррита на землю (холодный провод ТВС тоже прямо в землю) Что происходило: отмечалось падение тока на  первичке (незначительно), и в разы увеличивался на вторичке, (у меня перегорела лампа, пришлось подключать нагрузку в виде спирального обогревателя мощностью 1,8 КВт для дальнейших замеров) ток вторички значительно подлетал, прирост энергии порядка 400-700% (такие цифры исходя из тока питания первички и что получал на вторичке) игрался пока из-за перегрева не коротнула вторичка. Да чуть не забыл: очень важен зазор разрядника, у меня максимальный эффект наблюдался примерно при 0.5 - 1мм. поверхностью для разряда я использовал контакты из автомоб. реле припаянные на концах болтиков. Обычный провод быстро обгорает, меняя характеристики разряда, что в целом очень негативно сказывается на работе установки. За основу я не брал ни чьих схем, всё рождалось экспериментально. Чего и Всем советую. Переведите сами. Всем СЕшникам успехов.
Tomtech29
Some of the diagrams are showing that the two yoke secondary coils are going to separate coils?
I think personally that are connected in such a cor- responding or by Termistor NTC .at the point of the earth, of course.
you have the right to improve but you can check ine consumption of power sources enegi,How have the effect of?
oo...
at this stage of the unfortunate design does not run their forward while touching the potentiometer to its cycle damaged one of the transistors This control is not acceptable
it will be necessary to develop a large stable control system,still a long road ahead.
(Unless of burned transistors has already Ruslan?) ;D
These short pulses and attack combinations are so strong compactness for keys.
quite a challenge for the correct design ,and good thinking for authors.
successful recreation.
