0 Members and 58 Guests are viewing this topic.
magpwr
hi everyone,
Testing with kacher revealed nothing today,not surprised.No current movement to Earth detected.
Final testing on Sunday with 4.8kv EMP generator which is generated from tesla coil using 12volts to 300volts DC via capacitor bank.
I have converted my setup using 12volts battery.Small toroid is bypassed at center tap of large toroid to improve output using 12volts battery.Take note i am able to bypass this small toroid since i am
running at 40% duty.
I have attached the latest screenshot using 12volts supply.
Researching into Grid Tie inverter i found out that output waveform would need to be in phase with mains supply waveform 50/60hz in order to lower power consumption as supplied by solar cell.
I would need to investigate on how to step down using nearly 100turns bifilar winding via 0.47uf capacitor to 3turns on yoke or toroid and this waveform from 3 turns on yoke would need to be in phase with 28turns.
I noticed that waveform across 3 turns is around 20volts Vpp which is in phase with the waveform obtain from the bulb base on current setup without kacher.
Tomorrow i shall know if the high voltage nanosecond pulse in kv would able to deliver sufficient current/voltage across 3turns on yoke/toroid after high voltage pulse is step down from the 100turns winding.
I'd believe that the 3turns is the input and the 28turns on yoke is the step up.
For new member my connection to kapanadze wiring  diagram was obtained from member URFA in this topic.Original source Ruslan.
http://www.youtube.com/watch?v=vfrFmM8eh2A
NickZ
  It's hard to know which schematic actually works. As each one is different, and most were made by guys that have not
obtained self runners, yet. Except for Ruslan, and each of his diagrams is also different.
But, as no one is making an exact replication, or using the same wattage bulbs, ground lines, input sources, etz... so many of the component values may not apply the same, in all these different cases.
For example, the ground on the above diagram is 18m, yet Ruslan uses 37.5 meters, which is the same as the grenade output coil.  Same thing with the (resonator) inductor coil, some are using longer or shorter sizes,12,12, turns, or 24,24,  different tuning caps, different caps at the output next to the bulbs, and so forth.  It's all very confusing... so, we really need to focus on a single device replication, and share results.  But, that doesn't look like it's going to happen, as there are no two replications made by our guys that are the same, or similar.
Tomtech29
Now i get it the negative cable is not connected to ground himself denied Ruslan
everything indicates that lingers in attenuating theory correct path of progress
-I heard him say that they do not announce that the truth of that because I worked on a project day and night I do not blame him, and that made a big fuss
all in one: thrown into a box and involved you have to be to not broke sapper They are not wrong :D
tion's nothing wrong with everything you need when trying to ::)
Enjoykin
Quote from: magpwr on April 25, 2015, 12:01:21 PM
Небольшой эксперимент с включением катушки сьема
http://www.youtube.com/watch?v=EqtJPtsX32A
Tomtech29
 :)Antanas already working on this or mustafa v2
other methods:
I'm curious to see how he works good luck.
