0 Members and 1642 Guests are viewing this topic.
magpwr
hi everyone,
Maybe it's seer coincidence that i just found out Akula tesla coil is the version with spacing in it.
To Nickz-Everyone else failed to spot this one hence no successful replication by anyone to date.
I have attached close up photo of Akula device which revealed there is spacing between each winding for the tesla coil.
I have attached my version of the 4.8KV EMP generator which is technically called a Tesla coil.The one which gave me 5Amp reading to Earth.
It's Sunday over here time to commence experiment.Time to redo my old tesla coil on pvc pipe with existing kapanadze winding.
NickZ
  Magpwr:
  We have previously looked closely at, and commented on that inverse wound flat copper wire coil, that's at the end of the Kacher secondary coil. Looks to me that it may be made of 1/8 inch copper braid, and yes there is a small space between the windings.
Try it, and see.  Every detail is important.  I'm using the same insulated stranded wire that goes around the 3 inch ferrite rod, or 3 inch bar in my case, for that purpose. But, there is probably a better option.
   Everyone should try to obtain a 3 inch size Tv yoke,  they're all over the place if you know where to look. And they're free for the taking most of the time. That way we can all be working on the same yoke/grenade device, but maybe using different driver circuits.
magpwr
Quote from: NickZ on April 25, 2015, 10:37:07 PM
  Magpwr:
hi NickZ,
Ruslan may have indirectly given us inspiration on how to wind a Kapanade coil which is one of the critical requirement.
"Recall it was really hard work contributed by many in this topic related to reverse engineering of the Kapanadze coil and Pvc diameter around 2014"
But i do believe Ruslan might have failed in his replication attempt including the dally replication.
The tell tale signs are already there when someone showed off a high power replication then decided to go for lower power replication using 2 large tesla coil.
It's different for Akula  case where he merely introduce and sold only the lower power version to the Chinese.
I have just completed winding after heading out just to grab a couple of masking tape.I think i have easily used 8 rolls of masking tape for Kapanadze coil and 1.5 rolls for this Tesla coil with spacing in it.
10 rolls of masking tape for $1.20  :D
Speaking of Yoke i got 2 which was purchased from a Russian seller.It was really hard searching in ebay for just the yoke core without the unwanted winding.
Dog-One
Sure glad you brought this topic up about the spacing.  I had totally overlooked it.  A rewind is in order...
What hit me when you mentioned it is that Ruslan's first device used the "nano-second generator" with the coax cable.  The Tesla coil is essentially doing the same thing, but it will only succeed if the impulses are sharp.  The only way to get these extremely fast impulses that roll or spiral the magnetic field in the grenade coil is to remove as much self inductance in the Tesla secondary as possible.  Inductance is resistance to change.  We want change, lots of it, real fast.
Not sure how you did the spacing, but I think I'll try winding two threads at once--one wire and the other nylon fishing line.  This should give me a pretty precise gap all the way along the coil.  With a little practice I should be able to find a size that gives me the number of turns I need plus reduce the self inductance enough to see some effect.
Thanks again for your comment magpwr.  That would have been real easy to miss.
magpwr
Quote from: Dog-One on April 26, 2015, 03:38:31 AM
hi Dog-One,
I have just completed connecting the Russian PIO capacitor 20uf 400volts as near as the primary coil as possible although i am not too happy about running long 2.5mm sq electrical cable which makes it looks messy and induce some lost.
But i am very happy that i managed to get more than 6KV nanosecond pulse after the counter turns from the tesla coil with spacing in it.
Strangely i find that connecting a 500volts 560pf Mica capacitor across 3 primary winding consist of 2.5mm sq perform better than my 560pf 50KV ceramics capacitor.
Current to Earth peak at around 3Amps at the moment.
I am currently doing first test run using the PLL default clock frequency without connecting the toroid and bulb yet.
Earth is connected to 12Volts Battery Supply negative at the Mosfet Source which the bottom of the tesla coil is connected to the Drain of Mosfet together with the primary winding.
This is the HV spike i am getting after swapping the connection to primary winding as attached.
