0 Members and 53 Guests are viewing this topic.
starcruiser
Quote from: magpwr on April 26, 2015, 07:47:54 AM
hi Hoppy,
For those like myself without a spectrum analyzer this is the only best way i know in order to know what is the resonance frequency of the multilayer coil(After all other winding is completed).
Using a normal tesla coil with a ferrite rod to be used to control frequency with the usual Antenna over 25turn bifilar.No PWM generator or yoke needed in this mode.
This is the only way for the bulb to be lit if you hit resonance via ferrite rod insertion from the bottom of tesla coil.
25 turns "bottom" a
nd Multilayer coil "top" along with source negative\kacher transistor emitter is connected to ground with the 5watt bulb.
Multilayer bottom coil is connected to the 5watt bulb.
25 turns "top" is left unconnected in this configuration.
After completing rewinding i used the above procedure in order to find the sweet spot for the multilayer so that 5watt 220volts bulb will be lit.
I found that by starting winding with 56turns from the 1st layer the resonance frequency is 1.62Mhz up from 1.58Mhz for my old winding which i started with 60turns for the 1st layer.
Used a multimeter or scope scope place near by would do the trick.
Take note Ruslan is using 50th and 100th Harmonics but i prefer Akula whom is using 60th Harmonics.If resonance of multilayer is 1.7Mhz then at 60th Sub-harmonics it's 28.33khz.
Just about to resume experimenting after evening tea break. :D
Earlier i found that the nanosecond generator does effect the bulb brightness only a small percentage while lowering current by <0.4Amps.
I do have obvious problems like my wire to Earth\water pipe is mere 2.5mm sq. :D
Last experiment for tonight  i discovered i that i am able to achieve effect similar to URFA only provided if i use the signal generator LTC1799 activated via jumper on my PWM generator board.
The bulb light will just fade away once i disconnect power to my variable HV voltage DC supply set at around 300...320volts.
It looks like at resonance using PLL i am unable to see much effect.
More research is needed pending till Thursday or Friday onwards.
@Magpwr,
Please note the multilayer Coil will be resonant at around 7.8xx Mhz since the wire length is shorter than the Tesla/Kacher secondary, thus the wavelength/frequency diff. You are looking at a resonant peak that is 1/4 down from the primary resonant peak if you are seeing a signal around the 1.8Mhz area. I have seen this on my testing with the sweep generator and scope when testing the secondary and grenade coil. We need to include the "top Load" (antenna) in the equation since this will impact the resonance of both due to capacitive effects. Just something to keep in mind.
An Update on my test rig:
I have made my Primary coils this weekend as well as the antenna coil, now I need to mount the assembly and coils to re-test them for resonance, then adjust the tesla/kacher secondary to tune. Once this looks right I will then start building the inverter circuit. I will post updates and pictures of the results when the resonant testing step is completed.
We need to be accurate in the tuning otherwise we will not see the expected results, good luck
Regards,
Carl
Void
Quote from: br549 on April 26, 2015, 10:20:13 AM
Several days ago I setup the SR Transformer Experiment (sort of by accident, I was working on something else) and noticed an interesting thing, so yesterday I saved this short video on YouTube. I think that I am going to do some more experimenting with this and see where it goes.  To all,   any constructive thoughts or direction are always appreciated.
https://www.youtube.com/watch?v=BIoUcDWB6i4
Nice experiment BR549.
All the best...
a.king21
Quote from: Hoppy on April 26, 2015, 11:01:52 AM
Hi br549,
Interesting experiment and similar setup to the Antanas circuit shown by Tomtech29 in post 8429. I intend at some stage to carry out some of my own experiements along these lines, not so much looking for that elusive OU but seeing how pulsed HV at various frequencies and timing, affect the apparent luminosity of tungsten filament lamps being primarily powered from an inverter. I get a distinct feeling that this fairly simple principle of operation may be the basis of Kapanadze's green and transparent box devices.
Why not study Kapanadze's  patents? He has 2...............................
Enjoykin
Enjoykin:
As always;
thanks and have a great day.
br549
Hello Rankin2000 !!  :D
Excellent experiment.  Very professional. You have best professional laboratory here.
Now you know secret of Kapanadze and SR193. Mixing current and HV - boosting output power.
I have made some suggestions for you at picture.
If you put rod antenna 50om via BNC and change input impendance of your tektroniks on 50om you can scan wide spectrum and seeing what is going on when HV unipolar pulse hit sinusoide. Will be fine if you make voltage, current and phase meassurements in your circuit. For current meassurement best is use of Tektroniks hall current probe or you can make current transformer and calibrate him.
Reg.
Enjoykin
Enjoykin
Петр Кривцов
One more replicator of Roman and Ruslan BTG.
https://www.youtube.com/watch?v=4vVWQ4JV7l0
