0 Members and 625 Guests are viewing this topic.
verpies
Quote from: d3x0r on November 22, 2012, 03:19:09 PM
The same way the outside coils influence everything inside of the coax?
The coax picks up a lot of the voltage from the other coils also.. so why wouldn't it participate the same?
Maybe what goes through the inside doesn't?, maybe it's just the outside reflection backwards that counts... and maybe only the outside is picking up the high voltage drive?
There is a difference between:
1) A pulse between the inner conductor and outer shield of the coax
2) A pulse between two ends of the inner conductor
3) A pulse between two ends of the outer shield.
Which one were you referring to?
In an ideal coax, the outside influence can happen only in cases 2 & 3.
In case 1, the outside influence can happen only due to coax leakage or the AB Effect, according to the current state of human knowledge.
Alfeen
Quote from: Сергей В. on November 21, 2012, 10:39:39 PM
Привет всем !!
.... to Alfeen As you have builded Tesla Transformer you have chance to start Energetic Revolution 2012 in Germany :) ...
I wish I had this chance, but this tesla coil takes 250W from the mains, makes very hot and dense sparks which can quickly melt 0,5mm copper wire, act as a "burning bush loudspeaker" and in the end wastes almost all of these 250W as heat. Not really an "Energetic Revolution". Some ordinary light bulbs can do this too!  :(
The feljpg_8864669_6350327.jpg you posted is lacking too many details and will hardly allow anybody to do a replication. From the Russian description I gather it worked inside a cage 2 meters in diameter? Can you point me to videos of this device?
Did you download the RAR archive and look into it? What does the guy say about coax cables?
kind regards
Hope
Making a sniffer loop pickup, we then should be able to find the "leak" point along the coaxial.  This topic at this point seems very close to the "tuned cable that was strung and produced (gathered) energy from the surrounding" that Tesla invented.  I am wondering if imposing a compounded magnetic field (focused) could be made to also be used as a carrier field for the extraction of the energy gained.  It is well known that  sensors made from focused magnetic beam are extremely sensitive to any particles crossing their beam (field).
The ESR problem causing oscillations (resonance) has been the subject of an article I found today at this link.
3rdHarmonic13.56MhzPush-PullClassEAmplifier
Notice the very high efficiency that this circuit was found to obtain in simulations, in the physical prototype this "Q" was not so easily to produce.  It is all explained in the research paper.
Hope
The basic suggestion to filter/block the ESR was heavy copper strips shielding the MOSFETS.
If the focused magnetic field is effective at any point to sense the energy, why not place many of the same magnetic field sensors all along the cable and harvest the combined energies?
verpies
@All
Attached here is an excellent article about MOSFET Driving and oscillations of high-speed SiC MOSFETs (such as the Cree CMF20120D) that is also applicable to Si devices.
I highly recommend studying it, especially Chapters 4, 5, 6.
