0 Members and 67 Guests are viewing this topic.
T-1000
Quote from: magpwr on April 30, 2015, 10:09:49 AM
Today i have confirm there is some kind of static buildup on the Antenna or even after the EMP generator(Tesla coil) output long after power is switched off.[/b]
The top load on Tesla coil is a capacitor plate made from coil as I mentioned in translation earlier. When you have good enough isolation the charge can stay for quite long period.
Also please note about spark color when Ruslan touches Tesla coil in his videos, it is not bluish or whitish. The yellow like color from sparks is there and it indicates the current build-up from capacitive top load...
NickZ
  Yes, but Akula's Kacher circuit HV spark on his second video device, is very small and IS blueish white, and does NOT stream. Showing lower voltage, and current output. Therefore, it's NOT in the 3 to 10kv range. And this higher voltage may not be needed, as SR193 also mentioned. The idea is not try to power the device from the Kacher's HV output, but to aid in the syncing of the proper frequencies, only.
  Ruslan is trying many things, some may work well, and some may not. His big Tesla coils device, while trying to replicate the Akula big Tesla coil device, did not pan out very well considering it's size.
  Mag:  How many caps are on your Kacher driver?  The neon draws very little power from the Kacher crt, and may just be lighting off of the caps. Disconnect the output of those caps and you're likely to see the neon go out.
Same effect as when Ruslan's PSU's green indicator light stays on for a while.
magpwr
Quote from: NickZ on April 30, 2015, 11:30:53 AM
  Mag:  How many caps are on your Kacher driver?  The neon draws very little power from the Kacher crt, and may just be lighting off of the previously caps. Disconnect the output of those caps and you're likely to see the neon go out.
hi Nickz,
I no longer believe in Ruslan although he is also good in Reverse Engineering.But his typical tesla coil by design is a failure in my eyes.
I don't wish to waste more time discussing about his old setup as all of you are following now.
I will not stop any of you if you like his setup or way of presentation for whatever reason.
Only the Kapanadze winding was useful to me the rest of the information i discard and not forgetting the simple nanosecond generator circuit design.
My variable 32volts...1600volts HV DC supply is set at 300volts which is connected to single Russian PIO capacitor 20uf 400volts which around the limit for my 1.2KV CREE Mosfet.
Long story short it is why i am able to get 7KV for less than 10watt of power using 12volts battery.
Simple Answer-
If you try charging flash capacitor to around 300volts would you able to simply light a test pen without close the loop.
To Hoppy,
I think i have made mistake in my winding after performing some basic calculation in my head related to the 2nd kapanadze winding/rewdining i have recently done.
1st time Kapandze winding 1st layer i started with 60,60,30,30,15,15  .The 5watt bulb lit at 1.58Mhz
2nd winding done recently 1st layer 56,56,28,28,14,12    .The 5 watt bulb lit at 1.62Mhz
For every reduction in 4 turns for the 1st layer the resonance of the kapanadze coil increase by 40khz.
In order for me to get 1.7Mhz resonance for the kapanadze coil it seems base on simple calculation i would need to reduce winding by further 8 turns for the lst layer.
This will increase the  resonance by around 80khz then + 1.62Mhz =1.7Mhz.
This means that 48,48,24,24,12,12 for the Kapanadze winding is the most likely answer/solution which i have to discover the hard way.
NickZ
  Seam easier to just wind the grenade with the recommended 48,48,24,24, 12,12 turns to use up the 37.5 meter line. And also connect it up to a 37.5 meter ground line.
  I'm not concerned about any of the older videos, as this is one of his latest ones.
   I have continued trying to obtain similar results as Ruslan on the video that is posted once again, below.
But, I can see that the my Kacher is not anywhere close to having the right operating frequency that will make my device perform as Ruslan is showing in the video. As my Kacher will not really brighten up the single bulb (10w 220v), only slightly. So, there lies the crux.
  He is drawing over 100w to light the 220, 60w  bulb, (24v, times 4.3 amps) that is being shown on the meters.
So, no overunity there, as Bat1 and others have also observed on their device, as well.  Until... the Kacher circuit is in sync.
  This video is what I was waiting for, as it shows the difference that using the right frequencies can make, on the bulb when only the 3 turns yoke coil, and the 12, 12,  or 24,24 turns induction coil (resonator), are used to light the bulb, without the 168 turns output coil connected to the push-pull oscillator.
   https://www.youtube.com/watch?v=Wj_OgBAF6GA
Tomtech29
I have a question for you that? maximum power load how many watts ...
at the output of only the grenade and the circuit LC( only 230 volt light bulb there none other)
-NickZ is inquisitive and it got me thinking how Ruslan plugged 60watt added 100 watt bulb together 160Watt and candles in half brightness
I already tried it and I'm curious of your achievements
Of course the power at the input PWM dc 24Volt
and the important thing how many windings on the inductor?
-When I changed the thickness of the ferrite core and windings noticed many changes. :P
