0 Members and 115 Guests are viewing this topic.
T-1000
Quote from: magpwr on May 01, 2015, 12:48:24 PM
This is to show that there is increase in DC voltage across bulb after providing power to Variable HV supply for the nanosecond pulse generator.
But it does increase the current consumption as well to around 75watt.
Ghm, that is a bit opposite in regards to power consumption than in other Russian experiments where power consumption drops and output increases.
Are you using correct polarities between Tesla coil, grenade coil and its inductor?
P.S> It was suggested by Ruslan to have standing wave between grenade coil and its inductor (the windings strictly should be one way direction for inductor) and another standing wave between top load of Tesla coil and Earth ground. Also the magnetic polarity between Tesla coil and grenade coil should be opposite if that was understood correctly..
Bat1Robin2
nick, I am sorry i am not trying to be annoying i am trying to post less often so as not to bother you or anyone else. But can you post a link to a video of running device and open boxes with no 12 volt batteries connected. I must have missed it in my 3 months of searching and watching every single ruslan video i could find multiple times nearly every night. The one called open internals is the closest but the second box is not opened and only a tiny peak into one little corner. I will wait for the link you provide. I truly do not wish harp on this but its true its just not shown in the open.
magpwr
Quote from: Hoppy on May 01, 2015, 01:03:53 PM
You are very close to the clamp meter reading on the Kapanadze Green Box device. All that is needed now is to lose the power supply and maintain the current reading for self-running.
hi Hoppy and T-1000,
The clamp current reading base on last round with 2.5mm sq wire nearest to water pipe is 4Amp nearer to device is around 9Amps.
I am now using 4AWG Cable meant for car bass system.Later i try to convert my large toroid into a joule thief which convert high current across 3 turns to voltage across 28turns.
"Base on my calculation in my head it should do some useful work"
Many people still don't understand why there is need for  3 different types of windings on the yoke in the 1st place.
Akula did mentioned the Yoke is the "catalyst" base on stivep translation of Akula old video.
Stick with Ruslan's you get zero current movement to Earth.But i really do "admire" your ardent support for Ruslan from a distant land.
NickZ
    Guys:
   I've just made another video, showing some interesting effects that I've just noticed on my device.
   It's too late here now to post it, but I'll upload it onto youtube tomorrow, and place a link here.
   Bat1:  Sorry bud, but I'm not here to quench your doubts.
Enjoykin
Quote from: magpwr on May 01, 2015, 10:13:27 PM
..... Stick with Ruslan's you get zero current movement to Earth.But i really do "admire" your ardent support for Ruslan from a distant land.
Блин диву даюсь !!
I am shocked with such "IGNORANCE AND UNRESPECTFULNESS - TYPICAL AMERICAN ARROGANCE " >:(  >:(  >:(  >:(
Better support Ruslan Kulabuhov instead you. He has shown several version of BTG unlike you, You didn't shown nothing usefull. Only empty stories.
I was in dilemma - do i give you correct schematic and explanations or not. Simple i dont want that guys like @specialist magpwr@ take this schematic make device and start hitting a bells that this BTG and schematic is product of their mind. I bet it will be for sure - just after some time when people start launching their own BTGs.
So folks - here is schematic. Other parts you know. Who doesn't know can freely ask for technical details. Btw Oleg schematic is correct - after more than 10th versions of hardware modifications. His schematic is starting point. Who does not want make Katcher can make DSRD nano pulse generator based on schematic i was post in last year. That schematic with PLL circuit is correct. Only adjusting shape and amplitude of output pulses is very complicated without expensive oscillograf. For example Itsu 4 channel oscillograf is perfect for such tuning.
@NickZ Hi !!  I am surprised !! You can't buy oscillograf in Ex-Yugoslavia ?? What, they never heard for oscillograf ?? I suspect that. For sure you can buy one from EBAY or from Chinese EBAY !!
I will search for one fine old analog oscillograf for you.  :)
Reg.
Enjoykin
