0 Members and 96 Guests are viewing this topic.
NickZ
   Lost_Bro:
  There are many different PWM circuit on the market that do also offer frequency controls. Ebay has many available.
   The one that you linked to is only 8 to 12v, but there are some that will go up to 30v. Of course the price
can go as high as $20- $80.  But, some of those are high amperage models, even for induction crt, possibly well suited for our purpose.
   My time is also worth something, and I'm not really into building a circuit that can be bought, and used immediately. Especially if it can be purchased at a reasonable price.
   That's what Ruslan has been doing all along, probably paying someone like Aleg to design them for his particular purpose.
   I wonder what would happen if an induction hob is used, once modified, instead of the push-pull oscillator. As they are much more powerful, as some guys have seen, like Igor Moroz. His tests with using them, to light 2000w worth of bulbs, using only 500 watts input. Looping it has still been the main problem up to now, as most guys that have used them, have noticed.
stupify12
Quote from: NickZ on May 02, 2015, 04:30:09 PM
  Your English is good, thank's for sharing.
  Here is a picture of the small bulb that I'm using to tune the Kacher to the 3 turns coil, for best output. It glows a little more now as I placed the ground line on the other side of the bulb's connections. It is still not as bright as it could be, but it's brighter than it was when I made the last video, last night.
Hello Nickz,  Just consider this suggestion...  I think people on this thread are being led astray away from the real truth.. The Circuit / Electronic Diagrams which Ruslan had shown to others are correct and working but on the Main Coil people are being decieved.
Always keep in mind that there is only 3 Coils needed on this generator..  Actually it is much easier to follow Tesla than replicate people on the forum..
First Coil:   The exciter coil(Kacher, Capacitor Discharge, Mazilli type) . The very ideal frequency is from 6hz to 35khz of switching/ impulse discharge of the Capacitor..
Second Coil: The so called grenade coil( The combi of CW and CCW) . What is needed here is a coil with great inductance but lesser ohmic resistance.. To do wind this coil you need to wind a definite length of wire with a bigger area of coil former/ considerable Diameter.. Imagine a very lenghty coil wound in a expanding diameter or area, the resistance is diminished but the inductance is increase.. The purpose of this is to create a resonant tank with a lower frequency vibratory oscillation that can be readily used for our load devices..  A high inductance coil and a very small antenna for high frequency oscillation ; A high inductance coil and a very large capacity of antenna for low frequency oscillation...
Third Coil: The output coil wound to satisfy need and ground together with the Second Coil..  Charge capacitor 1uf to 25uf 400v and discharge in a modified sine wave set up like that output of the inverter and there you go you have a 60hz output...  4 Transistor in a H Bridge Circuit to discharge the charge on the capacitor for our load..
Stupify :D
Tomtech29
 :)lost_bro
I am trying to understand the system'm just a novice electrician the current system DRSSTC
it seems to me that I would be able to carry it out.
I can not compete with you Compliment fully deserved,as you would be kind enough please provide diagram.
will be much easier and another thing what you think about this scheme
I hope that I will not do harm to anyone to use someone else's work:
Enjoykin
lost_bro
Quote from: Tomtech29 on May 03, 2015, 04:15:36 AM
:)lost_bro
Good day Tomtech
Just a couple of quick thoughts regarding your PLL schematic:
1. Has the capability to select between Phase comparator typeI & Phase comparator typeII.
2. Uses the tried and true comparator input for signal control from Voltage feedback >> Pin#14 on PLL IC.
3. Uses Hex inverting Schmitt trigger IC for signal/wave shaping on input to PLL IC.
4. Missing important information regarding Current/Voltage feedback transformers.
4a. Is missing all values of passives.
5. Has double-ended drive capability for GDT(s).
6. Considering that it is labeled 'PLL_Schematic_inProgress' probably means you will spend quite a few hours de-bugging after fabricating.
Getting late, got to work tomorrow.....
When I have a chance, I will post with attachments some decent information regarding PLL inverters.
take care, peace
lost_bro
