0 Members and 59 Guests are viewing this topic.
Bat1Robin2
I made a 2 reason reply to nick.  This is what i said a couple days ago: nothing about resonance.
I do not think circuit board you listed would work. 2 reasons:
1st reason pulse width would most likely be too wide and not sharp enough for tesla driver. (since it only has a 1.5 mhz capability) it needs to finish the pulse quicker than that speed even tho it runs at 40 khz interval the pulse width needs to be slim.
2nd reason the circuit shown we are building in the schematic utilizes the bemf and dumps it back onto the floating ground or at the yoke it dumps bemf back onto the 24volt line. Almost all modern circuit drivers will simply burn away all  bemf as it serves no purpose for them. This will prevent this the driver board you listed from being efficient.
I assume you did not mean for the push pull yoke since there is 2 of them needed. For the tesla it simple will not have a sharp impulse. In order to push towards overunity we must harvest every ounce of bemf. Unfortunatly this means very little bemf burn off resistors and diodes & surge protectors.. This leads to the path of FET destruction if not done carefully.
That board is a big diesel tractor , it will drive good and strong and consume all your power as it does, dumping all bemf into useless resistors and diodes it has on board to handle such events. Then light up a led showing you its working good as it waist a little more power.
Guys: Think about how easy it would be to put a battery in one of those boxes and let the output feed back and power the digital ics only. As soon as the output to that power supply circuit cuts out for any reason. The ics loose power and the device stops and cant be restarted without external input again. So we have internal battery powering the FETs and the output powering the ics. Very simply magic trick and the crazy thing is it is the same thing Lester Hendershot did on his device. 2 years later they figured out he was using a pen battery of the time inside. Also in the same video where i spot the funny cylinder device you watch the volt meter trickling down from 1000v to 970 or so constantly dropping all thru the video, very suspicious for a device that is suppose to be overunity. One more thing i want to mention is thru-out the videos there are some places where he is writing number on papers and it looks a lot like time for example 15:23, 13:45, 14:25... This in my opinion could be length of time until battery runs down. I may be wrong and nick is all mad at me for mention all this im sure. But he is blind without a scope and religiously believes in this device which is not even shown open. We all are being sadly fooled be careful what you spend your money on, and consider that you will need to use it for something else later on when this don't pan out.  Sorry nick i will post less and let you guys watch ruslan show you closed boxes that are overunity.
NickZ
  Bat1:
  Sorry bud, but I can't even finish reading your last post.  Guess why?
MenofFather
Quote from: Tomtech29 on May 11, 2015, 05:30:02 PM
someone replied to the forum ;) :Can use  [/font][/size]74HC132 or 74HC00
To complement MenofFather, I add the pinouts of the 74HC00 (or 74HC132) in your schematic too
This hands me fall .
if someone reads and verifies this information   (Yet the two other ICs)
If you asking about this schematic or it work? Then aswer is yes. I made pulses with that schematic http://realstrannik.com/media/kunena/attachments/234/74hc00impulssynchro.png
Red is output. And you need reverse that pulses with driver or in other way...
Hoppy
Quote from: Bat1Robin2 on May 11, 2015, 11:11:22 PM
Although IMO Ruslan is almost certainly faking his self-runner(s), Nick says he is trying to replicate Akula's device, which he believes is a genuine self-runner. I wish him the best of luck, especially as he is handicapped in not having the necessary test equipment and currently lacks basic knowledge in electrical theory and experience in electronic circuit build. Like others, I have genuinely tried to help Nick by answering his questions to the best of my knowledge, but I sometimes feel that he is not helping himself.
I agree that Ruslan's slowly descending voltmeter reading was the giveaway / smoking gun to him having concealed batteries. I had not noticed him writing times down on paper but this would make sense if he was running on batteries. Nick can get as mad as he wishes but this forum welcomes people with all viewpoints, whether they be positive or negative views on a given subject.
gyulasun
a little confusion here and there -and so it is with the entire system
Hello Tomtech29,
I am not sure what your problem is, please clarify which ICs you ask about?  Maybe the 5V and the 12V voltage stabilizer ICs?
Here is the link to my post where you can see your schematic what I edited by adding the pin numbers of the 74HC00 which were missing.   http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg449710/#msg449710
IF you mean this schematic with the 4 ICs:    74HC00      uCC27321    7805    7812
Gyula
