0 Members and 307 Guests are viewing this topic.
NickZ
Quote from: gyulasun on May 09, 2015, 09:55:22 AM
Hi,
To complement MenofFather, I add the pinouts of the 74HC00 (or 74HC132) in your schematic too.
Gyula
Do you have a clearer version of the above schematic, with your pinouts, and maybe explaining or showing the input source, and  about the L1, and Blue line that's next to the fet. I can't really read all the values.
  EDIT:  This copy is correct?  At least is can be read well.
Tomtech29
Hi.
it seems to me that the two other ICs
The 74HC132; 74HCT132 is a quad 2-input NAND gate with Schmitt trigger inputs. This
device features reduced input threshold levels to allow interfacing to TTL logic levels.
Inputs also include clamp diodes that enable the use of current limiting resistors to
interface inputs to voltages in excess of VCC. Schmitt trigger inputs transform slowly
changing input signals into sharply defined jitter-free output signals.
why the input suppose to be: 74HC00
what is the difference between them(The 74HC132;74HC00)?
The 74HC00/74HCT00 are high-speed Si-gate CMOS
devices and are pin compatible with low power Schottky
TTL (LSTTL). They are specified in compliance with
JEDEC standard no. 7A.
The 74HC00/74HCT00 provide the 2-input NAND
function.
it's like for me this fits the 74HC00 is against the mosfet driver
photo # 2 I do not understand the configuration.
photo # 1 74HC132 instead of switching to 74Hc00
Tomtech29
Tomtech29
gyulasun
Quote from: NickZ on May 12, 2015, 11:12:28 AM
(http://realstrannik.com/media/kunena/attachments/971/Sinxro_var_VID1.jpg)
Hi Nick,
From circuit function or the IC operation points of view I think the schematic
you linked to seems to be correct.
I do not know about L1, my best guess is it is a coupling coil and serves
as a primary coil of the 'Tesla' coil shown on the right hand side, perhaps
other members who already attached some versions of a full setup designed by
ALLEGGA could tell you the number of turns and the wire diameter etc.
I can only help occasionally in interpreting certain circuit schematics.
The blue line is nothing else but a drawing or separation line between the MOSFET
driver and the MOSFET, just part of a frame line. You can see such blue (in the lower
left corner) or green etc rectangular frames in the big schematic attached to this post:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg449723/#msg449723
As I can see from the link, the input source you asked comes from either the output of the
PLL IC, 74HC4046 or comes from the output of a Schmitt trigger 74HC14 as an inverted PLL output,
these are shown in the green framed part of the big  schematic.
I edited the schematic you linked to and numbered the pins of the ICs and attached in a zip file
(it is too big to attach it directly).
EDIT  I checked the ZIP file after I downloaded it and it reports a damaged file when unzipped but
still it seems openable...  this is a Forum glitch...
See also this link as an alternative download to the same schematic and click on Sinxro_var_VID1.jpg :
http://overunity.com/downloads/sa/view/down/581/
Gyula
