0 Members and 322 Guests are viewing this topic.
gyulasun
Hi Tomtech29,
You may wish to use an IC socket for the 74HC00 and later when you have a HC132, just plug it in instead of the HC00.
Sockets: http://en.wikipedia.org/wiki/Dual_in-line_package
Gyula
PS  would like to ask you when you upload pictures or drawings as attachments to your posts, please try to reduce the horizontal pixel number of your pictures to 800 or 850 as a maximum value.. This way we do not have to scroll forever to the right hand side of the page to read the text line by line.  You used  1449x706 or  1536x978 pixel sized pictures in the previous page and you can see the result...   :D    I know that picture quality suffers when we reduce pixel numbers but a 800x600 or max 850x600 pixel size is still acceptable.  When there is really a need for high resolution pictures, then there is the Upload/Download section of the Forum on the left hand side column, it can accept max 5 MB size picture files. Thanks.
NickZ
  In trying to understand the function of the different components... turning a sign wave into a sharper and cleaner square wave,
is what this Schmitt trigger is doing.
  But, when viewing the Ruslan scope shots, it looks like he is showing a sign wave.
  So, that it may not matter, if the final output wave is of one type of wave, or the other, while it's at the proper running frequency.
  I just wonder if that whole part of the circuit is really absolutely needed, just to see the effects.
   Tomtech: Are you going to be mounting your components on a PCB.
   We need to have Oleg make us some sample boards, like the ones that Ruslan is using.
   Maybe T-1000 can ask Ruslan, if we can order some boards, even maybe ready built up, to test out.
   That way we can all building and working on the same basic device.
gyulasun
Quote from: NickZ on May 13, 2015, 09:52:23 AM
Hi Nick,
It sounds good what you try to do, however it would be better to know which part of a full circuit Ruslan happens to show a sinewave...  maybe he shows it too but then the next step is to realize if the circuit part he measures the sinewave can indeed work with sinewaves etc etc.
A MOSFET switch should be controlled by a sharp pulse while a tuned, resonant LC circuit may create a sinewave from pulses.
If Ruslan indeed has used a circuit very close to the full schematic referenced in the previous pages (for instance by Bat1Robin2 in Reply #8577  or what I found here: http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/dlattach/attach/147446/image//
then I think all the circuit parts shown there are needed, you could not omit any part of it. At least you cannot till the working principle is fully known and then circuit improvements could be made.
It is also possible that a combined wave, like a sinewave waveform chopped with some pulses or a modulated sinewave is desirable to get a claimed output power. The biggest problem is that it is not known how any extra output is received beyond the input (if we accept there is extra output).
Gyula
gyulasun
Quote from: Bat1Robin2 on May 09, 2015, 12:10:38 PM
Schematic again with my notes.
Hi Bat1Robin2,
I read your comments and notes in the schematic you kindly uploaded to your post.
I would like to ask what result you received?  (because you sound you actually built the shown schematic)  Did you notice any "promising symptons" that indicate more output than input?
Thanks,  Gyula
NickZ
  Gyula:
   In this video, Ruslan is showing a diagram which shows a sign wave marked next to both of the yoke's secondary coils output to the grenade coils.  And also,  an impulse wave of unknown type (to me), for the Kacher's antenna output.
   This diagram was made by Ruslan, not someone else, but, each new diagram of his is a bit different that the previous one. Like in this diagram (in the video below), there's NO short jumper connection shown between the 3 turns coil, (at the tuning cap 0.47), going to the 28turns/168turn crt. Each circuit is independent. Unlike his previous diagrams.
https://www.youtube.com/watch?v=1LhF261VDQw
