0 Members and 349 Guests are viewing this topic.
magpwr
Quote from: NickZ on May 14, 2015, 06:01:22 PM
  Hopefully my bulbs will also brighten up, as well.
  I am listening, Hoppy, and I'm buying this 20mhz scope as you recommended.
  I'll be working on improving and updating my device as needed, until it works.
And then some...
    Cheers,
                Nick
hi Nickz,
If you ever decided to buy a scope do buy the one which comes with a inbuilt frequency counter like the Rigol i'm using.50Mhz version Rigol is still the best buy since it's internal hardware is the same as 100Mhz which the firmware can be patched.
It would be nice to know exactly what frequency are your PWM generator running at along with the duty cycle display.
To everyone,
This is the latest findings of mine related to the tesla coil.
My instinct is telling me Akula is using NST to drive the tesla coil at 1.7Mhz or at 1/2 of 1/7Mhz which is still one of harmonics of the multilayer coil.
My simple justification just take a look at the thin white wires which is connected to the primary of Tesla coil or Kacher.
This thin wires is not suited for nanosecond pulse at all.
I do know this firsthand because there are lost induce for nanosecond pulse application which need high current pulse using thick wires to properly drive primary coil.
Did a quick research last night i found that NST is able to drive tesla coil in the Mhz range.
Trick is L/C resonance of the primary would need to match the resonance of secondary coil with it's Antenna."This is important"
Since there was mention of 3.5KV and 36KV in Akula tesla coil tuning pdf as attached in my last posting.
NST(Neon sign transformer) is the only one which would allow me to achieve at least 36KV from the secondary coil.
Once above setup is completed a simple "spark test with any metallic object" at the one end of the ferrite rod with 5 turns and 5 counter turns will in theory produce spark.Just like the old Akula outdoor video where he just use a bulb at the end of the ferrite rod for presence of spark test before switching on bulbs in the self running mode.
Base on Akula's translation in the pdf at "21:21 impact velocity of the
atoms is almost equal to the impact velocity of the atoms is a hydrogen plasma."
Oh Boy this theory of Akula is way over my current education level at the moment.I'm only in my 20s. :-X
I think i need to give myself an Unofficial "Phd in Reverse Engineering". :D :D :D
SeaMonkey
Good move and good choice NickZ!
Both of my scopes are old CRT with unimpressive specs
by today's standards but are more than adequate for
every troubleshooting task or project build I've undertaken
over the past 45 years.
With a little practice you'll be able to determine frequency
measurements with careful technique and a calculator.
You will never regret this investment.  When it comes to
circuit analysis and finding answers to tough questions,
the scope has few equals.
Let the progress proceed forward with new momentum!
Tomtech29
...magpwr
https://www.youtube.com/watch?v=f1a1qcvNLVU
I do not agree with your theory, there is a pulse on Tesla for a packet
and he says, not without reason there is no such type FET transistor IRFP260...460...
at high frequency that the signal says to deform!
besides, it's not lest high current necessary .
on the timeline in the middle of the sine using semiconductor and this part of the corrected fill up the signal from Tesla.
pay attention to the spacing distance and rip during the course of the sine
the rest is left secret for yourself
There is also an interesting moment where he is talking about charging coil like a typical capacitor type semiconductor diode barrier
this is how cor- charges the capacitors and receives pulses on the bulb flashes
Ruslan discovers not everything it is obvious there is something and it's not battery
stupify12
Secondary length should be 1/4 of the wavelength. 2Mhz is 150meters is the wavelength, that is the secondary grenade coil is 37.5meter.
When the length of the secondary is determined, it is our own choice whether we liked it to resonate on a higher frequency or lower frequency.. For higher frequency add a smaller top load capacity, for smaller frequency add a bigger diameter top load capacity..
NickZ
    Tomtech:
   Do you speak, or at least understand Russian?
   Ruslan is mentioning many things at the end of his videos, but I don't understand any on it.
   When I hear talk about (sorry for the spelling), Katushco Condenzater, and Resonator coil on some
other Russian videos, seams like interesting stuff. And I wish that I could understand what they're saying.
