0 Members and 334 Guests are viewing this topic.
Tomtech29
 ;)respect Nick/AllThe Russian language is to understand many words are the same or similar
in the old days where there was nothing in the shops and was a martial law All children learn Russian or German.
38 Years in back.
And about which part are you asking it seems to me that I can translate
-I know this feeling like you do not know the language a feeling of matches and torments
but this is you do not worry about (You do not do anything by force)
you have to keep a distance because otherwise it gets tired and let go of  as others have said, no one Akula device.
And what's interesting is why ?
And Ruslan himself personally answers the question his answer is:
a very important piece of information watch movie time 11.16 He says to understand and (katuszka) is a coil .is part of bifilar winding it works and behaves like a capacitor. It loads the particles of electrons
and this spiral around the coil :antenna: is not called antenna!  only a capacitor to fill or if you prefer charging!
Tesla explained on this as there are two capacitors on plane
-1 top with aluminum foil  coil with a capacitor must be tuned to resonate please remember that there is always another impedance with a hat.
-2 second bifilar coil is to be wound so that gave energy time:11.57
-3 Coil Inductor last served We give alternating current(AC)  in then you will get you produce a magnetic field N / S
as you understand how to charge and discharge the magnetic field. Using high voltage!!!
time 12:44
now you mentioned it: Akula uses another transistor that operates at high frequency of Russian KD...
why? transistors of the MOSFET type, not suitable  signal which goes on Tesla has farakter laceration saws...
otherwise the coil will not aligns.
Time redirected impulse to base this transistor is the key solution
also says that when this transistor opens and closes a signal formed of a (front)
(forum was a theory of standing wave) is not for me to judge
:)you need something let me know I will try to improve.
By the way, anyone know why I get hot IN5406 these diodes in the bridge rectifier at the output of the inverter.
NickZ
  Tomtech:
   Is that picture of your set up?
   The IN5408 series diodes that I used got hot on me.  I tried to use them for my full bridge rectifier, after the grenade output coil, but, they melted their solder points. The IN series diodes did not work for me. I think that the UF series diodes are better at HF.  Or the diodes that shown in the schematic. There's too much current going through the IN series diodes, and the get very hot.
  I'll re-read your last post again, as you said a mouthful there.
   quote:
  "a very important piece of information watch movie time 11.16 He says to understand and (katuszka) is a coil .is part of bifilar winding it works and behaves like a capacitor. It loads the particles of electrons
time 12:44
also says that when this transistor opens and closes a signal formed of a (front)"
        end quote.
   I thought that there was something there in that Ruslan video, that I should know about.
The Katuszha/Condezater effect, between the Kacher antenna, (falsely called) and the 12, 12, or the 24,24 turns inductor coil (Resonator).
  In my set up, the sync between the two circuits mentioned above don't really work as they should.
For the proper capacitor/coil effect, etz...  and, so it needs further tuning.
   So, a IRFP260N mosfet is NOT suitable for the Kacher driver circuit, then, right?
   Both Akula and Ruslan mention different transistors for the Kacher (like part #2sc5200),
And  IRFP2907, for the push-pull oscillator crt.
   Ruslan might be using the 70v 200A mosfet now, I forget the #,  and not the IRF260P.
  Each schematic is different, with different components. It's hard to replicate, that way.
   Good luck with your project on the driver circuits. I'm waiting to see your results, along with
anyone else working on this device.
  Here are some considerations on components to choose.
Using the best type of push-pull crt mosfet, as well as the red WIMA 0.47 2000v tuning caps, are very important, I feel.
http://www.irf.com/product-info/datasheets/data/irfp2907.pdf
http://www.ebay.ca/itm/10-PCS-IRF3710S-TO-263-F3710S-IRF7310-Power-MOSFET-57A-100V-/291181679741
http://www.ebay.com/itm/1pcs-WIMA-MKP10-0-47uF-0-47-F-2000V-5-pitch-37-5mm-Capacitor-MKP1U034707G00J-/161433959976?pt=LH_DefaultDomain_0&hash=item259636be28
gyulasun
Hi Folks,
The 1N5406 is a general purpose diode designed for max some hundred Hz frequencies like the 1N4007 series.
You may wish to use fast switching diodes,  there is the UF5406 with the same volt and amper specifications but
they are already fast.
See this link to see different ultrafast diode types, consider those indicated as ultra fast recovery:
http://www.futurlec.com/DiodesPower.shtml
for instance type MUR460G is a 600V, 4A ultrafast diode, etc. The Schottky power diodes are also fast types but their reverse breakdown voltage range is under 100V or max 200V only in case of MBR20200.  Of course there are many other vendors with other choices.
Gyula
Tomtech29
 >:(These rectifier diodes should be with my old converter (can not get it comprehend what happened)
They should work with the converter? and it is so that energy consumption will grow together and the next moment they are hot
-replacement of the bridge rectifier  bulb shone and bumm. 20Amper closed circuit at the output.
such as, for illustration or 5020 something to 1000V. The bridge probably will be the same.
NickZ
  I think that Ruslan is using those fatter higher output range diodes, now. I'll look into the parts number.
  These fets are a much higher amperage, up to 200A, 75v. And probably are the best for the push-pull crt.
   And these caps are what Ruslan is using, two or more in parallel, for the 3 turns coil. They are part of what makes
his spark for strong, when shorting them out with a screw driver tip, to show the power of that spark.
  Wima.  http://www.ebay.com/itm/1pcs-WIMA-MKP10-0-47uF-0-47-F-2000V-5-pitch-37-5mm-Capacitor-MKP1U034707G00J-/161433959976?pt=LH_DefaultDomain_0&hash=item259636be28
  Commercially made 50 or 60hz full bridge rectifiers, will NOT work, and will overheat immediately.
