0 Members and 261 Guests are viewing this topic.
AlienGrey
Yeah! Well.. I like your style asking a commercial company if we can all copy thair current money spinner ! well good luck ;)  on that one.
NickZ
  Does a guy named Oleg sound like a commercial company to you?  What money spinner?
  Do you suppose that Ruslan has made all those videos of all his devices, along with the all their schematics, just to keep things secret?
   Good luck to you, as well.
Pirate88179
Quote from: TinselKoala on May 21, 2015, 01:18:00 AM
And... by the way.... just in passing..... the MOON reflects plenty of light that it receives from the Sun back to the Earth, especially when full. And every planet, Mercury, Venus, Mars, Jupiter, Saturn, Uranus, Neptune, even little old Pluto... are only seen because they REFLECT SUNLIGHT from the Sun back to the Earth. How can they do this if there is "no sunlight in deep space"?  There is plenty of proof that your assertion is false, but of course you ignore it all.
Thanks TK.  These exact points were to be in my next post here.  Regular ground telescopes can only see light and, as I know you and millions of others use them to observe many distant planets which could not be seen without light, and where there is sunlight, there is heat.
PS  The satellite that is being launched to do a near fly-by of the sun is going to be very interesting.  The mission has to be planned very carefully so the satellite arrives in position at night so it does not burn up.  (Just kidding)
magpwr
hi everyone,
I have further improved and simplify the circuit design for the Tesla Transponder project and reduce total power consumption by around 80% which was previously hovering around 10watts.
This time i have replaced the HV supply with Disposable camera circuit using 1xAAA which would charge the 400volts 20uf Russian PIO Capacitors to around 260volts while the circuit is in operation.
After the HV Supply replacement the total power consumption of the Tesla Transponder is circuit  around 1.8watts (9volts battery is able to power up the Tesla Transponder stage.Think about it. )
while easily achieving 4Amps ...5Amps pulse to Earth.
This is the breakdown of power consumption of the Tesla Transponder circuit in details-
HV DC Supply using disposable camera circuit-
1.5volts x 0.94Amps = 1.4watts    (1.5volts battery will be replaced by simple step down voltage regulator later on)
Nanosecond generator circuit and 25volts (XL6009 voltage boost circuit) for Mosfet driver-
12volts x 0.034Amps = 0.408Watts
I have attached the screenshot to show that i am now using around 44ns to drive mosfet gate.The output of nanosecond generator 74HC132 is connected to mosfet driver IXDI614 pin2 via 150Ohms resistor.Pin 2 is connected to 150pf capacitor to GND to reduce stray noise on breadboard.
Another nice discovery i made today the disposable camera circuit would only charge a hv capacitor to little more than it's rated voltage example Russian PIO Capacitor 400volts would be charged max 425volts if circuit is not in operation.
I suspect once the leakage current in the capacitor would be increase to a point which would match with the tiny transformer on the disposable camera circuit.
In other words the HV capacitor will never be destroyed because of this simple but effective features...low current HV transformer.
Base on the latest power consumption at below 2watt for Tesla Transponder revealed that there is high possibility  that a 9volts battery can be used to self start device before supplying power to the
bulbs.
In other words current movement to Earth is for real and so is the possibility for a 9volts battery to start up device to go into self-running mode.Do think about it.
As Asian i do find it funny this old technology was originated from America via Tesla but was "neglected" by fellow Americans years back.
But the Russian was able to further improve base on this old technology.
I do find this amusing.
Hopefully i am able to solve this self-run problem later on. ;)
I have attached my youtube video of Tesla Transponder containing circuit diagram for your viewing or downloading purpose.
http://www.youtube.com/watch?v=D5jRpPHfA1Q
Dog-One
That is indeed pretty interesting Magpwr.
So let me ask just to be sure I'm understanding...
You can keep the high voltage cap charged with just the little flash circuit even when you are pulsing the Cree MOSFET?  The cap voltage stays constant?
If that's the case, this simplifies things considerably.  In fact, if you look at the original Akula circuit, he uses extra windings on the push-pull transformer to get his high voltage, instead of the way Ruslan did with a separate high voltage generator.  With the pulses so small, the push-pull driver shouldn't even see the load.
I had thought up to this point is was necessary to discharge the pulse capacitor, but from what you are stating, that doesn't appear to be the case.
That's a really good find Magpwr.  Very helpful!
