0 Members and 251 Guests are viewing this topic.
NickZ
   Mag:
   Try to see what bulbs you can light as a test of the Kacher/grenade output, without the 168 turns coil connected to the yoke crt.
   Looks like Ruslan is able to light a 60w bulb, or even a couple of bulbs, this way, while his running frequency only drops slightly.
   I'm still just learning about all this also.
   If you want to have a low current input for your Kacher circuit, you should check out the "Slayer Exciter".
As I've run them as low as 0.5 volts, and a couple of milliamps, while lighting CFL's, or LED's.
   Normal Kacher crt, are big power hogs, for what they can actually do. But, it looks like it will take some current as well, to make the grenade resonator coil react as expected, by the superposition. Just HV with little current, won't do it.
At least that's what I'm seeing.
Hoppy
Quote from: NickZ on May 22, 2015, 11:01:10 AM
....... But, it looks like it will take some current as well, to make the grenade resonator coil react as expected, by the superposition. Just HV with little current, won't do it.
Good observation Nick.  :)
" It sort of reminds me of one of Kapanadze's dynamo projects, remember Hoppy?"  - Yes indeed! Another device with a big enough box underneath to home a community.  ;D
NickZ
   I wonder what happened to ol' Kapanadze...  Will he tell his secret, before, not after he passes away.
Sad, I think, and such a waste, if any of his projects were true.
   The blue grenade coil that we've been working with, was his baby.
   So, I'm hoping to see some similar results, in a positive way, some day.
Pirate88179
Quote from: NickZ on May 22, 2015, 09:33:20 AM
  Yes, Hoppy. Just another fake...  There's actually a guy inside the box turning the dynamo.  Ha!
   Guys, I find it amazing that we really don't even know that there is no light in the solar system, there is no light "traveling" anywhere. The emitted light by all of the planets is being produced by themselves, with the help of the Sun.
  Light does not travel, there is no "movement" of anything involved. Light POLARIZES at the rate that is called the "speed of light".
   The real hoax Hoppy,  is what we are still being taught as fact, when in fact, it's all wrong.
   No one needs to repeat what is common knowledge, as it's still being taught in all the schools.
   Yes, I did go to school, some of the best schools, and the same misinformation is still being taught.
   I know that most will not believe what I'm saying, that's ok.  I expect that. Just remember that you heard about it.
   WE are being tricked for a reason.  That reason has to do with what we are trying to do here.
   I could explain what is really happening, but, no one is interested.  So, believe what you will. You'll see soon see for yourselves.
So, Voyager 1 that is traveling near the edge of the solar system is powered by what then?  I mean, it has solar panels which have powered it since its launch, but, if there is no light in space, why is it still getting energy to the solar cells?
I don't mean to sound argumentative here, I just don't see how you can draw the conclusions that you have when there is so much evidence from known science, and real world working examples that appear to contradict what you are saying here.
I am being serious here and am interested to try to understand why you are thinking the way that you are.
Thanks,
NickZ
   Bill:
   There is no way for you, or for me to try and prove what we can't prove.  Same thing concerning the Aether.
So, let's just let it ride for now.
   As what you believe is that there is bright hot Sunlight all the way to the Sun, and also throughout the whole entire solar system. Also, that satellites as far and farther than Pluto are able to use solar panels in deep space to provide for their power supply. But, that is not the case. It's extreme cold, and totally dark out there, once away from all planetary influences.  All you'll see are planets, stars, and such, giving off their own light. Not reflected light. There many dark planets, nebula, and large comets that don't give off light.
   Light does not "travel", as we are being taught.  It polarizes at the rate erroniously called the "Speed of Light. There is nothing, no thing,  moving,  even in a lightning strike.
    All I ask is that you remember that you heard about this. Even though you don't believe it, now.
    Just keep it in mind, or discard it, if you like.
