0 Members and 67 Guests are viewing this topic.
verpies
NickZ
  quote from a.king.
   "Nick Z
"Has a point".
Light is only produced on reflection.
Heat is only produced when molecules are agitated.
So you only get heat from the sun when matter is irradiated by sunlight.
You only get light from the sun when an object reflects that light.
Otherwise it's dark and cold.
This topic does however deserve it's own thread."
        end quote.
   The ideas above are not what I had mentioned. I said:  There is NO heat, and NO light is deep space. Light does not come from the Sun to the Earth.  There is no real understanding about how light (in general) is really produced.
   I really do want to focus on the Akula/Ruslan replication that everyone here is interested in.  As I got a kick in the butt after trying to convey some real and unknown facts. I won't lose more time and effort trying to explain, how wrong things really are.
I just wanted to bring up the fact that we are being lied to for a reason. For those that might be interested, in further looking into it.
  Ok...  No more about that from me, on this thread. Nor will I start a new thread, just to get hammered again.
You can believe what you like.
lost_bro
Quote from: magpwr on May 28, 2015, 04:16:07 AM
hi lost_bro,
It's interesting i have achieved this effect Modulation& Frquency Splitting waveform few days ago which appear in the center of the  scope which you have attached.
This effect is not easy to duplicate as i find it is also dependent on the HV DC voltage which i supplied for the experiment.
Base on one the Akula video i have implemented interrupter circuit using just 74HC132 with stream of 50ns pulse superimpose on 28khz 40% duty for the Tesla Transponder to get this waveform effect as attached.
http://www.youtube.com/watch?v=9sYLdekiLD0
It seems my experiment is limited by my 1KV rated variable capacitor,need to go for fix high voltage 3kv or more for fix value capacitor at later stage related to version 1 waveform with 12volts instead of HV supply as attached.
For this interrupter base experiment i need to use my 12volts to 220volts inverter to charge the 20uf 400volts rated pulse capacitor.
For Akula replication using Tesla Transponder without any modification to the coil.
1)Single HV pulse         -2watt of power needed
2)Using interrupter to achieve the waveform as attached on the Antenna -12Amps to Earth at below 20watts at 1.6Mhz...2Mhz
Lastly i will try using interrupter with flyback since logically this is the only one which can exceed 30KV pulse and another observation Akula was using thin wires to primary coil of tesla coil.
My plan is get all this HV pulse transmitter sorted out before commencing Akula replication which i would need to setup up on the floor.
Good day Magpwr
Yes, I agree that the gated pulse concept is definitely more efficient and gives more precise control.
Do you have a copy of the schematic shown in the Akula video that you posted? If you do please post it.
I my opinion, the process he demonstrates in that video is the basis for the waveform synthesis/resonance that is used in all these devices. Without that mastered, nothing else matters.....................
take care, peace
lost_bro
DA1
Good Day  Nick.
วงจรนี้สามารถดึงกระแส AC ได้จริงเปล่า
NickZ
  DA1:
  Good day to you as well.
   I'm not sure if I understand the above diagram. I would need the rest of the circuit to study it better.
Please resize any other images to less than 1500 pixels wide, or it will cause a problem on this site.
  @ All: I've had some set backs with my input source batteries and battery charger, all seeing better days.
So, I'm using a different car battery for now, connected to my solar panel, so that I can continue with further testing of the circuit.
   I'm still waiting for my Tectronics scope to be brought to me, which has been shipped to a friends of mine's house in the U.S.
I'll be getting the scope here, in a couple more weeks.
   In the meantime I fixed one of my problems related with my Kacher's low output seen at the antenna, which had not been working well lately. This turned out to be due to the side mounting supports on the grenade, who's too low a height negatively affected the Kacher's output power. That has now been corrected, and the Kacher is working as it should. But, it took me some days of looking into it to figure it all out. As there was no heterodyning effect to be noticed lately from the Kacher's output, to the 12, 12 turns inductor (resonator) coil. As I had seen and shown in videos, previously. So, at least that problem has been resolved.
