0 Members and 346 Guests are viewing this topic.
DA1
Quote from: NickZ on June 06, 2015, 10:26:09 AM
  DA1:
  Good day to you as well.
   I'm not sure if I understand the above diagram. I would need the rest of the circuit to study it better.
Please resize any other images to less than 1500 pixels wide, or it will cause a problem on this site.
  @ All: I've had some set backs with my input source batteries and battery charger, all seeing better days.
So, I'm using a different car battery for now, connected to my solar panel, so that I can continue with further testing of the circuit.
   I'm still waiting for my Tectronics scope to be brought to me, which has been shipped to a friends of mine's house in the U.S.
I'll be getting the scope here, in a couple more weeks.
   In the meantime I fixed one of my problems related with my Kacher's low output seen at the antenna, which had not been working well lately. This turned out to be due to the side mounting supports on the grenade, who's too low a height negatively affected the Kacher's output power. That has now been corrected, and the Kacher is working as it should. But, it took me some days of looking into it to figure it all out. As there was no heterodyning effect to be noticed lately from the Kacher's output, to the 12, 12 turns inductor (resonator) coil. As I had seen and shown in videos, previously. So, at least that problem has been resolved.
Thank you very much  Nick.
ขอขอบคุณมาก
ผมได้ส่งภาพที่ผมได้ทดลองบางส่วนมาให้คุณดู    จาก  thailand (ประเทศไทย)  คือผมสนใจระบบนี้
NickZ
    DA1:
   Nice to see that you're actually building an Akula/Ruslan replication.  Welcome to this thread!
   Looks like you've got a good start on your version of the device. Great!  Keep at it until you obtain a self runner. \
   Try to post a video when you can, explaining what you've achieved, so far.
   Looking good, as you're able to light the small bulb from the Kacher's output only. That's a good start.
   Good luck to you.
                                NickZ
magpwr
Quote from: lost_bro on May 28, 2015, 05:48:34 PM
Good day Magpwr
Yes, I agree that the gated pulse concept is definitely more efficient and gives more precise control.
Do you have a copy of the schematic shown in the Akula video that you posted? If you do please post it.
I my opinion, the process he demonstrates in that video is the basis for the waveform synthesis/resonance that is used in all these devices. Without that mastered, nothing else matters.....................
take care, peace
lost_bro
hi lost_bro and everyone,
I have attached the simplified version of the actual circuit of my latest Tesla Transponder 2.0 interrupter version with actual  passive component value used.There isn't 74HC132 in Multisim. :(
But in my experiment all gates are 74HC132 with additional 4th gate to create non inverting stream of pulse which is connected to 150Ohms then to input of IXDD614.
Take note i am using 39pf between IXDD614 input and GND on breadboard to prevent noise.Mosfet driver output is connected to Cree SIC Mosfet via 2.2Ohms 2Watt resistor.
The output of IXDD614 (23.5volts from boosted supply)should have individual pulse width of 76ns which somewhat match the Ton /Toff in SIC Mosfet datasheet to get optimal results.
Latest improvement to circuit i've added (yellow/white) toroid with 1 turns which is around 0.5uH from positive around 230volts DC to coil.This improve the stability while tuning the capacitor 1KV 20pf..1nf which is set to around 55pf...73pf.
I am now getting 2.2kv Vpp stream of pulse which i got 18Amps....34Amps to Earth using less than 20watt of power.This is not easy feat to achieve.But it is more easy for me to get 5Amp to 12Amps to Earth.
I think this is good enough for kapanadze Antenna maybe.
I have attached my record 34Amps nearer to device and nearly 20Amps to Earth nearer to pipe.
It seems choice of mosfet is very very important i am using 1.2KV Cree SIC Mosfet which outperform the 1KV IXYS RF Mosfet.
The resonance frequency of my Test Tesla Transponder coil with Antenna coil connected via 5 cw,ccw ferrite rod is around 4.3Mhz.
But i am merely playing with it's sub-harmonics frequency at 291khz to obtained the results as attached.
The resonance frequency of the 4 turns primary coil with variable capacitor 50pf<75pf is around 15.3Mhz.
I've obtained the Virtins 2A20E usb spectrum analyzer to find out the sub-harmoncis frequency of my kapanadze coil.Later stage i may or may not show show on how to play with sub-harmonics. :D
Spectrum Analyzer is a must have tool.I'm sorry to say that but i am just being honest.I don't wish to pressurize anyone into getting something if you don't know what you are doing in the first place.
I have pasted the link to my Proof of Concept video once more to prove the current movement to Earth is for real via Tesla Transponder video v1.0.
http://www.youtube.com/watch?v=D5jRpPHfA1Q
Tomtech29
Welcome back.
I had a short break This observed on little I could do nano-second system is presented in which I swapped
260 IRFP transistor on the NPN 2SC5200 at 46 volts and capacity of 5 Amper got short rec emitter to the collector.
I scaled the entire frequency range from 43 kHz to 230Khz and I failed to observe changes in the output of the coil grenade still I do not know what could be the frequency generator to the Kacher
magpwr-He has done interesting work ,the frequency with which it plays is higher 291Khz.I'm curious one test on the chip coil Akula how it will look as fit system with grenade on exit and not on the side of the measurement coil?
the target is to understand how the system can work Thank you for sharing experience.
-I'm not entirely convinced that the signal received at the antenna is to generate the power to ignite the bulbs the output coil grenade?  with some comments Ruslan said he uses one half the course to load capacitor This is the base to maintain rapid recharging the capacitors
this hyperactivity You can be seen on the bridge and capacitors not polarized the vertical pins signal...
from what I understand it as a coil output grenade and bridge rectifier (DC)---? and pulse capacitors .Now pay attention to what he says This impetus that we get there and the other thing that was constant voltage DC current to AC power
really are a lot of misunderstandings one theory is very fast load capacitor and the other from the railways charge coil grenade.
request ...
- What do we know about it?
I can be wrong :(if we have the low frequency resonance and should provide alternating current) on the other hand we receive a high frequency pulse to give a high voltage itself
as we know, without electricity (Ampers.) voltage does not light bulbs (60Watt).
where did they come from additional amps?
how does it affect bombardment pulses of high voltage Tesla coil?
since the effect of what I see we give plenty of power to ground instead of the inverse process of suck?
Tomtech29
-I had in mind for suction in the ground( magpwr ) of blocking diode to connect the grounding cable :D
and what will the effect on the ammeter? or all of the.
