0 Members and 280 Guests are viewing this topic.
NickZ
     It would help if Magpwr is sending 34 amps to his earth ground system, to SHOW what those 34 amps to ground can actually do.
Will those 34 amps light a bulb, or not? So, far he only has only shown the meter readings as proof of concept. And we know that amp meters are not showing a correct reading, as they only work well when using them with 50 or 60hz.
    A Tesla coil wastes most of it's energy by dissipating it away into the air.  Nor do I think that the ground is actually providing any useful amperage. But may possibly be allowing for the yoke/grenade circuits to pull in extra energy from the surrounding ambient towards the ground, providing that there is an actual tune earth ground system.
magpwr
Quote from: Tomtech29 on June 07, 2015, 08:20:21 AM
-I had in mind for suction in the ground( magpwr ) of blocking diode to connect the grounding cable :D
and what will the effect on the ammeter? or all of the.
hi Tomtech29,
This is my only unconfirmed theory which keeps appearing in my head for now.
Each time the Tesla Transponder(Transmitter) sent pulse down to Earth and at the same time there would be a void or suction effect created on the Antenna.
This Antenna suction effect then assist the receiver coil/Kapanadze coil to pull ""whatever"" from the ground or Earth which is acting as counterpoise.
But i do hate to speculate before the chicks hatch. ;D
At the moment i am merely playing with transmitter using it's harmonics without receiver coil at all.
This is the zoom in photo of Akula device which inspired me to create this Tesla Transponder video using my Reverse Engineering skill.
Take note i am not following Ruslan at all.But you are free to decide whatever way you choose.I no longer wish to spent unwanted energy to convince anyone that Ruslan is fake.
Hoppy
Quote from: NickZ on June 07, 2015, 10:14:50 AM
Nick,
Yes, its possibly a very misleading reading as you suggest. A rupturing in-line 500mA or 1 Amp fuse may show if there is any voltage behind it. However, it could be a reasonably correct current at very low potential. My Fluke clamp meter is not useable above 10KHz. I'm sure that Mags appreciates all this and think he is just demonstrating the Kapa 'Green box' device effect and not necessarily suggesting that it provides any useful current.
Its good to see the thread back on topic.  :)
NickZ
  The image that DA1 just uploaded, does show the working relation between the Kacher's output being able to light a small DC bulb connected only to the grenade's output coil.  If this does not happen, then there is no real effect generation of the superposition between the Kacher's antenna output and the 12, 12, or 24, 24 turns induction coil on the grenade. Nor will a light bulb be able to light at the 168 turns output coil from only the Kacher's output.
   On the diagrams that Akula and Ruslan are showing, the Kacher oscillator circuit is being feed by the rectified DC voltage of 220+volts. And not just 12 to 24v, or so. That may explain the big HV sparks at the Kacher's secondary coil and antenna, that is shown by Ruslan. But, not by Akula, as his spark is much smaller, and almost invisible to see.
  Both guys are also showing that there no shocks when touching the bulbs, or their output connections.  That part I Love.
Tomtech29
Hi all.
Magpwr so I was thinking only how to try the system, such as modified the: (See the diagram below) whether it has any meaning as you think?
much has been said about the type of electron pump and to some extent the importance it would have made sense
I am not able to otherwise recognize how we deal phenomenon when it is so significant surge of current from the angle?
NickZ
many of us have tried and still need to continue to look for (
for the light bulb at the end of the grenade only powered by Kacher) ...I would not hold so tightly you know each other as it's not hard to do, Then the problem is that when pulses arrive in a single transistor and capacitor is not the same as the systems G.ns
whether it's official ending any effort in this topic and you all think it does not work
or something I missed out? :o
