0 Members and 311 Guests are viewing this topic.
Tomtech29
...The image that DA1 just uploaded, does show the working relation between the Kacher's output being able to light a small DC bulb connected only to the grenade's output coil.  If this does not happen, then there is no real effect generation of the superposition between the Kacher's antenna output and the 12, 12, or 24, 24 turns induction coil on the grenade. Nor will a light bulb be able to light at the 168 turns output coil from only the Kacher's output.
-This found resonance with coil grenade so much in this topic <<a small bulb of 15Watt to 25 Watt lights ok.
This when combined winding biffilar LC give him a raise voltage to the output 40Volt more and so much connect 150Watt bulb and no longer sees the strengthening, the need for better luck and possess considerable knowledge as they convinced themselves no offense to all.
NickZ
    Tomtech:
    Is the diagram above representing what you are building, or what you would like to build?  Looks good to me, but does it work?
   Yes, the right caps are very important. The two or more red WIMA 2000v 0.47 tuning caps used on the 3 turns coil, may be critical to see that big spark
there, when the caps are shorted.  They cost 12 to 15 dollars, for each of those capacitors.
    I get increased light output at the bulbs if I short out the 3 turns coil at the tuning capacitors, but, also increased consumption, and heating of the fets, as well.
    Please upload any pictures of new results, or videos.
  EDIT:  You said: "This found resonance with coil grenade so much in this topic <<a small bulb of 15Watt to 25 Watt lights ok.
This when combined winding biffilar LC give him a raise voltage to the output 40Volt more and so much connect 150Watt bulb and no longer sees the strengthening, the need for better luck and possess considerable knowledge as they convinced themselves no offense to all."
        end quote.
   Tomtech, I don't fully understand what you are saying (above). Nor do I understand what Ruslan is saying, either.
But, I can see that the 60w bulb does light much better when Ruslan connects the fuse to the Kacher circuit, thereby adding the HV, to the yoke/grenade circuit, as well.
magpwr
Quote from: Hoppy on June 07, 2015, 11:25:14 AM
Nick,
Yes, its possibly a very misleading reading as you suggest. A rupturing in-line 500mA or 1 Amp fuse may show if there is any voltage behind it. However, it could be a reasonably correct current at very low potential. My Fluke clamp meter is not useable above 10KHz. I'm sure that Mags appreciates all this and think he is just demonstrating the Kapa 'Green box' device effect and not necessarily suggesting that it provides any useful current.
Its good to see the thread back on topic.  :)
hi Hoppy,
Since i am using low end clamp meter which is design to work up to 400 or 500hz sine-wave.The metal core on clamp meter looks similar to the 50/60hz typical mains transformer.
In order to know how high frequency can a typical transformer go using narrow pulse width-
I assume you got a signal generator to inject narrow pulse say 76ns...100ns at 1volt starting from 2khz onwards to primary winding of mains transformer and observe how high the frequency can go before the signal starts to drops again in the secondary winding.
In another words before the core starts to saturate.
I think this is the only way i can convince you that the core on low frequency clamp meter won't get saturated easily at higher frequency using narrow pulse.
That's all for this week.
By the way the 220volts low power bulb do dimly lit between bottom of Tesla Transponder coil and Earth.But i am no longer interested in this effect.
AlienGrey
Hi Tomtech29  and all, in the circuit you have published you have displayed a oscalator  frequency at the ferrox core of 34,15khz and 6mm coil windings, i don't want to appear rude or unkind but if one is using a TI494 at 12volt, I tried building t a few devices like this and got no where, for a start i could not get any of the device's to go up that high in frequency and secondly the ferrox core is unturned as it's wide bandwidth, and 6mm wire is unreal as it's like gas pipe and to push real power through that device you need very high voltage power and capacitors to match, this  is a joke  right ?, In truth the frequency we should be tuned to should be much lower than that if we want to get this idea to work, also from what i can understand the 50 turn coil should be 3 times that frequency  so 1.736 Mhz is not right either, I would assume that it's closer to the EHT coil  'frequency' unless you know what your doing and how it's supposed to work your wasting your time and no one to my knowledge has managed to replicate this device yet  so have fun. PS if i were you I would find out what the frequency is where you can get maximum return energy from the earth like Moray reported, also i would look at how his machine worked as well.
DA1
hi Nick and everyone,
สวัสดี นิกส์ และ ทุกๆท่าน
วงจรนี้ที่ผมได้แนบมาให้คุณดู  มันหน้าจะเป็นไปได้ใหม  ผมได้แก้ไข(edit)  บางส่วน :D
