0 Members and 217 Guests are viewing this topic.
Tomtech29
I greet you all.
I decided to make video material for you because only so I can convey to you what I understand This material is not intended to argue that the device works!
This is just my opinion in this direction and please do not blindly trust in the final truth as far grog for me.
systems need to change and strive to improve and so the sea to prove it does not work now for many of us.
AlienGrey( and you have some reason) it is not easy  I do not know what I'm doing I'm doing is certainly not the way we would speculate about it you have to try as who is able and as we can or something of that will or nothing? Anyway, thanks for the kind words
I am looking for answers and I will continue to look for ...
I've always been  learn from you and help each together.
https://www.youtube.com/watch?v=m1a-FUyTuOI
Tomtech29
NickZ
Thanks for the support that I have so much on my side.
- This chip TL494 It is only temporary You will need another oscillator for push-pull signal to generate a range of 20kHz to 40kHz in synchronization with the PLL phase lock.
someone on the forum already presented a ready PCB.
I appeal to those who want us to support.(I am able to make anyone design) PCB-hole single-layer in PDF format or other. is here many of you who have thought out project ,I'm eager to try to do it at home and show you how it works
... Why I have not done?    I can not do it all alone and I can ask you.
AlienGrey
Whitch of the PCB designs do you want the layout for ? this one ?
AlienGrey
NickZ
  Tomtech:
   I'm impressed!  Great video!!!
   You are seeing similar results as what I'm seeing, but, since your input  voltage is twice as high as mine, the effects are more noticeable.
   You sound very excited in the video.
   Thanks for sharing your results, so far.
    Best of luck...
   DA1:  Give that circuit diagram a try, as is.
   GeoFusion:  Where are you?
   Here's a couple of pics of my set up. 12v 2amp input from a wall adapter running both the Kacher crt, and the 3 turns yoke/grenade coil circuits.
I've improved the Kacher's output, since the picture below, and it will now light a CFL bulb up to about 7 inches away, when before it only lit to 1 inch away.
  Last picture is the latest Ruslan push-pull driver.  That's what we need to replicate. And maybe the schematics and specs are already available on it.
