0 Members and 343 Guests are viewing this topic.
T-1000
The circuit in ZOLTAN ferro magnetic collector.jpeg does not seem to be OU.
Here is calculation:
1.5V / (R1+L1) 800 Ohm = .001875A (18.75mA) The coil adds impedance  so 13.174mA seems valid there.
Also L1+M1+R2 current value of 5.159ma seems valid for a frequency 20kHz.
Also in the 0:58 of https://youtu.be/bXwfFV4DIyk video the effect I talked about is manifesting very well there... ;)
Cheers!
Hoppy
Quote from: Acca on June 18, 2015, 08:39:24 AM
I consider the Ruslan power device very dangerous in the ownership.. To own one is a big risk..
Thanks again Acca for the additional long list of links.
Why is the Ruslan power device very dangerous? Do you have first hand experience of operating this type of self running device?
I assume the answer to my first question is that its because the device is operating on the principle of NMR. If that's the case, then maybe warnings about the dangers should be highlighted on the forums. I for one have no wish to continue experimenting with a device that could potentially be very dangerous to my health. Furthermore, given that this danger is real, I can perhaps now understand one reason why Kapanadze was unsuccessful in getting anyone to invest in his devices.
NickZ
    Acca:
   I watched the device videos that you posted the links to.
Like this one:https://www.youtube.com/watch?v=bXwfFV4DIyk
However, as I don't understand what he's saying.  I have some questions, that you might be able to answer for me.
   Andray's circuit, does seam to resemble my device in some ways.  But, does his device self run, or not?
   I see that the Kacher's output is adding to the small bulb's brightness, when it's connected to the grenade circuit.
But, what will it do with a load of 500 to 1000 watts worth of bulbs?  Will it self run then?
   Hoppy: Yes, I do love simple circuits...  Ones that don't need, nor use  "X-wires",  hidden batteries, and such...  to work.
  Acca: Here is a fairly resent picture of my set up, which I'm still working on.
MackorLab
Hi, everybody!
We developed the digital module about which Ruslan in one of the videos speaks.
It has full galvanic isolation to 1500V. And universal food 3.3V and 5V for opportunity work with "Arduino" and "Algorithm Builder".
Speed of data increases because of that that we don't spend time for inclusion and data processing about internal ADC, and we have external-independent, working at frequency up to 80 MGhz and we only address for data to 10 bit port.
starcruiser
@Acca,
It does seem that this device might be using spinwave power generation, the ferrite rod next to the coil would be the source of additional electrons/power then from what George Bugh states in his latest video. The aircore coil would be the field coil, the kacher would be the exciter, the antenna coil could be a plate in a capacitor (asymetrical perhaps?), the real antenna would be the wire wrapped on the rod that would "Kick" the atoms precession to create a wave which is induced into the aircore coils which would re-enforce operation.
To increase output then, we would need to add a few more ferrite rods around the aircore coil near the one end and tickle or Kick (choose your analogy) them using the HV source and place them in parallel for increased current. the coiling on the ferrite rod is relevant then (phase) to collect the magnetic wave and then induce it to the aircore coil via the radiator (large antenna coil).
The only ting to be sorted then is the timing of the kicks to the field, which I think the low frequency field is used to align the atoms, or re-align them, between HV kicks. The question then is the 27Khz frequency being used relevant? or just convenient?
OF course this is a hypothesis at this point.
What are your thoughts on this idea?
Regards,
Carl
